2007 Rancher 420 Relay Issues - Honda ATV Forum
 1Likes
  • 1 Post By Nanook12
post #1 of 3 (permalink) Old 05-24-2019, 03:57 AM Thread Starter
buckied's Avatar
Hello all,
New here. I've come searching for info and hoping someone has seen a similar problem to the one I'm having. I bought a 2007 Rancher 420 4wd foot shift model. It has a bad starter I believe which is no big deal to replace, you can tap on the side of the starter and get the engine to spin over. My main issue is with the key on, kill switch in run, and the headlights off the fuel pump/engine stop relay will sit there and click very quickly, 2 to 3 times a second I'd say. If I turn the headlights on the clicking stops. If I turn the kill switch to stop the clicking stops and what I assume is the fuel pump turning on briefly like it does when you first turn the key on if everything were normal. If I push the starter button the clicking stops. I've replaced the fuel pump/engine stop relay and that didn't change anything. I cleaned the battery to engine ground cable connections along with the engine to frame/wiring harness ground cable connections with no change as well.
Any thoughts?
Thanks for any info you guys have in advance.
Justin
buckied is offline
post #2 of 3 (permalink) Old 05-24-2019, 05:16 AM
Nanook12's Avatar
Liked: 57 times
What is the battery voltage? Sounds like the battery may be weak.
ktriebol likes this.
2008 Honda Rancher, manual shift, Alum Rubicon (old style) wheels & tires. Warn R/T 2500,
2015 Rubicon, manual shift, 3500SR Terra Superwinch, Strongmade receiver hitch.
2018 Foreman, manual shift, 2500-S Warn Provantage.
Nanook12 is offline
post #3 of 3 (permalink) Old 05-24-2019, 07:25 AM
ktriebol's Avatar
Liked: 123 times
I agree with checking the battery voltage when cranking with the starter. As far as replacing the starter goes, you probably only need new brushes that come with a starter repair kit and are quite inexpensive.
2015 TRX500 Foreman
ktriebol is offline
2007 Honda 420 rancher 4x4 issues DJF New Member Introductions 1 02-13-2019 09:35 PM
2018 Kodiak 450 vs 2018 Honda Rancher creed82 ATV General Discussion 41 01-28-2018 07:18 PM
2007 Honda Rancher 4x4ES Parts interchangeability jawsfree Repair & Maintenance 8 11-14-2017 10:32 AM
2000 Rancher ES issues nokin24 Repair & Maintenance 5 08-11-2017 05:24 PM
2007 Honda Rancher 420 starting issues jeepguyclh Repair & Maintenance 10 02-09-2016 05:41 PM
