2004 350 Rancher 2x4 Wrist pin frozen to connecting rod - Honda ATV Forum
 2Likes
  • 1 Post By DIESELTECH
  • 1 Post By Jeepwm69
post #1 of 7 (permalink) Old 05-03-2019, 10:48 AM Thread Starter
TexasTide's Avatar
I purchased a 2004 Honda Rancher 2X4 manual shift Sunday. The motor was locked up and the crank case was filled with "Mystery Oil". I pulled the head and freed the piston from the cylinder. I removed the jug but could not get the wrist pin out of the piston (yes, I removed the keepers). The piston will not pivot on the rod. So I am going to do a complete rebuild. I have zero experience on this motor (my other ATV has over head cam) so I am looking for a shop manual. Does anyone know where I can get a good shop manual? Also has anyone had the piston wrist pin seize to the rod and if so what was the root cause?
TexasTide is offline
post #2 of 7 (permalink) Old 05-03-2019, 10:55 AM
DIESELTECH's Avatar
Here’s what I did when I was given my rancher 350.
Take rags and stuff them in the hole so no debris gets in the motor!! Very important!
I took a cut off wheel or a dremel and cut the piston in half perpendicular to the wrist pin. The piston will/should fall off the pin.. then I took a long bolt with some sockets/ washers and I pushed the wrist pin out.
Then took my dremel and a sanding drum and VERY carefully cleaned the rod up and test fitted the new wrist pin.
Mine has been like that for over a year now and no problems or noises
trailridr likes this.
DIESELTECH is offline
post #3 of 7 (permalink) Old 05-03-2019, 10:59 AM
Liked: 2937 times
What dieseltech said will get the wrist pin out, but be sure and check the rod to wrist pin fit on the new wrist pin. I strongly suspect that you'll have to have a new rod put on the crank if that thing was run to the point that would seize it up to that degree.
retro likes this.
post #4 of 7 (permalink) Old 05-03-2019, 11:06 AM
Liked: 2768 times
No, don't try to run that rod... the pin bore must be in perfect condition for them to survive. And the pin clearance must be precise. I'd split cases and sent the crank off to Vince at Mrcrankshaft.com for rebuilding and truing with a new rod kit.
post #5 of 7 (permalink) Old 05-03-2019, 05:11 PM
LedFTed's Avatar
Liked: 415 times
this forum is a good place to start.
https://www.hondaatvforums.net/forum...s-manual-help/
"sometimes, when drinking 5 or 6 bud's, nipping JB, Jim Beam, cinnamon in between, i start thinking sideways,,i have to though, to match the way i walk" ed
2000 450es TRX
2 grass hog 4x4s
sum humor adds up
LedFTed is offline
post #6 of 7 (permalink) Old 05-03-2019, 06:32 PM
Liked: 4210 times
'' mistery oil '' ?, what..water ?..lol. oil filter put in backwards ?, sunk..then ran will lock them up all day long. time for a new rod, top end kit. may as well just rebuild the whole motor seeing how your already in this deep :-).
post #7 of 7 (permalink) Old 05-08-2019, 05:54 PM
Greg Smith's Avatar
The dealer I have dealt with for years has rebuilt cranks for 350 rancher with heavy duty rod trued indexed etc 149.99 and complete rebuilt engines for 350 rancher 1yr war 1195.00 email if need more info etc. thanks
Greg Smith is offline
Handlebars Moparman318360 Honda Rancher 6 12-05-2018 04:45 AM
2018 Kodiak 450 vs 2018 Honda Rancher creed82 ATV General Discussion 41 01-28-2018 07:18 PM
2004 350 rancher knocking YellowRancher Repair & Maintenance 29 10-21-2017 10:10 AM
2004 Honda Rancher light bar Wolfeman Honda Rancher 0 10-01-2016 09:38 PM
