2013 420 rancher fuse blown/shift issue - Honda ATV Forum
 1Likes
  • 1 Post By Melatv
post #1 of 7 (permalink) Old 04-25-2019, 06:34 PM Thread Starter
Camohoyt340's Avatar
I posted this on another forum and I just learned about this one. I have been searching for some help with this for awhile. What happens is this... I can put it in EPS mode and start it up. It says it’s in 2nd gear. I can ride around in 2nd gear and sometimes I can shift to 3rd gear. If I try to shift below 2nd or above 3rd, the 30A fuse labeled “Main 1” blows. When I try to put it on auto, the same fuse blows. I removed the shift motor and cleaned it. That really didn’t make much of a difference. It maybe shifted a little better but still blew the fuse. I tested the shift solenoid and it seemed to be working. This quad has 2k miles on it. We have an upcoming poker run on May 11th. to benefit my mom who just had a bone marrow transplant. I’m hoping to have my quad ready for then. Maybe you guys can help.
Camohoyt340 is offline
post #2 of 7 (permalink) Old 04-25-2019, 06:56 PM Thread Starter
Ill also add that I do not have the exact manual for this machine. I have one that covers up to 2011. I’m not sure what/if changes were made between the years but I was told that they are similar enough. I’m an industrial mechanic (work on big machines) so I really don’t want to have to take it to the shop I just need a little help pointing in the right direction. I just unplugged the shift motor and started it up. It didn’t blow the fuse when I tried to shift but i really don’t think this proves anything.
post #3 of 7 (permalink) Old 04-25-2019, 09:04 PM
Liked: 3154 times
First thoughts are that it sounds like either a shorted wire somewhere or a failed ECM... so far. Don't buy any parts yet tho, until you've got some proof to lean on. As for finding the problem that might take a considerable amount of time. I would look at the service manual wiring diagram for clues and be unplugging things one at a time and checking circuits & switches with a multimeter until the fault can be isolated.
My first question would be: Are there any non-OEM Honda electrical parts on the bike? If so, remove those and test again. If not, begin by testing high current drawing components first.
Check the shift switches too... neutral, reverse, auto/drive, etc. Also check the charging system output in case the regulator/rectifier might be spitting out high, AC-laced charging voltage. Max charging voltage should be about 14.5 - 14.7 volts DC revved up.
Is the battery in good condition? Clean terminals and grounds?
EDIT: Also be on the lookout for an internally corroded/melted wiring harness connector. Scrutinize the condition of the fuse box sockets as well.
post #4 of 7 (permalink) Old 04-25-2019, 09:14 PM
Liked: 3154 times
Also don't forget to turn the ignition switch off each time before unplugging/reconnecting a harness plug or component. Voltage spikes can fry ECMs.
post #5 of 7 (permalink) Old 04-29-2019, 04:14 PM Thread Starter
Thank you for your reply. I am going to get to work on it again tonight. I’ll take a look at those things.
post #6 of 7 (permalink) Old 04-29-2019, 04:18 PM Thread Starter
No I have no aftermarket parts on the quad. It’s 100% stock.
post #7 of 7 (permalink) Old 04-29-2019, 06:34 PM
Melatv's Avatar
Liked: 311 times
Hi: Remove the shift motor from the shift gear case and run the shift motor with the up & down buttons to see if the 30 amp fuse blows. If it doesn't blow the fuse remove the shift case cover and check the condition of the gears.
retro likes this.
25" Kenda K587 Bear Claws HTR
2500 Runva Winch
Melatv is online now
2006 Rancher FE (ES) blowing ignition fuse hbender1 Repair & Maintenance 2 12-16-2018 02:56 PM
Help!2 2001 rancher 350 4x4 FM fuse issue! Please newhope Honda Rancher 10 11-25-2018 02:42 PM
2013 rancher 420 ES shift issue chvyluvr417 ATV General Discussion 6 10-31-2018 09:27 PM
07 Rancher blowing fuse Richard Rose Repair & Maintenance 10 07-05-2018 04:17 PM
2018 Kodiak 450 vs 2018 Honda Rancher creed82 ATV General Discussion 41 01-28-2018 07:18 PM
