97 Honda foreman 400fw! Headlights and tail lights will not work!!!??? - Honda ATV Forum
 5Likes
post #1 of 62 (permalink) Old 03-10-2017, 08:54 PM Thread Starter
bleedhonda3's Avatar
I have what I believe is a 97 foreman 400fw that my buddy was gonna junk and I couldn't let it go to waste because I'm a Honda guy and it has a new top end including a jug and a new carb. It just needed a few things and cosmetic work... Anyways I thought my headlight switch was bad cause it was original and I had no lights anywhere so I installed a new one and still no lights! I've checked every plug and fuse I can find and still have no idea why I do not get power to the wires for any lights?! Any input will be greatly appreciated!
bleedhonda3 is offline
post #2 of 62 (permalink) Old 03-10-2017, 11:29 PM
Liked: 4279 times
a 12 volt dc test light works wonders for tracing power loss !.
post #3 of 62 (permalink) Old 03-11-2017, 07:27 AM Thread Starter
The problem is the color of the wire keeps changing color and I'm trying not to just destroy the harmed pulling it apart
post #4 of 62 (permalink) Old 03-11-2017, 10:22 AM
Liked: 4279 times
you don't need to pull any wires apart ?, just start at the fuse block and battery, most are big red wires, they go to the fuse block, then to the ignition switch, from the ignition switch, they go to the light switch then to the lights. most wires for lights are color coded white, blue, and green for Honda. this is a very simple trace test, just takes a little time to trace.
post #5 of 62 (permalink) Old 03-11-2017, 10:23 AM
Liked: 4279 times
and when I say a 12 volt dc test light ?, they have a sharp point on them, they are made this way, so you can probe right through the wire insulation without destroying the wires :-).
post #6 of 62 (permalink) Old 03-11-2017, 10:25 AM Thread Starter
Ok I've got several testers I'll give this a shot ASAP! Thanks!
post #7 of 62 (permalink) Old 03-11-2017, 10:33 AM
Liked: 4279 times
your welcome. don't forget to remove the head light socket, turn the lights on at the switch, and see if your getting power to the socket ?, could just be a corroded socket ?, bad light bulb ?, hard to say ?, but that test light sure makes it easier to narrow it down :-).
post #8 of 62 (permalink) Old 03-11-2017, 10:34 AM
Liked: 1411 times
Does this machine run otherwise? Do you get taillights and brake light? Oh I see you said no
Do you have the manual there should be a schematic. Check in vicinity of gas tank could be there's a broken wire or loose connection caused during the engine or carb work.
Goober is offline
post #9 of 62 (permalink) Old 03-11-2017, 10:36 AM Thread Starter
There's is no power at any sockets at all there are no tail lights or headlights. I was installing flush mount cubes and couldn't get power to them so I started testing every light socket and I get nothing. The bike runs good I just need a new starter relay to start it right now
post #10 of 62 (permalink) Old 03-11-2017, 10:49 AM
Liked: 1411 times
Ok i would think there's a harness connector unplugged. Referring to the schematic, I would start from the fuse box (main bus) and go forward. Locate each connector. Inspect for connection and look for broken wires on the back shell of each connector. Once you are satisfied they are all connected then go back and test for power with the test lead by connecting to the hot lead and touch ground. The test lead will light if power is coming from the main bus.
Goober is offline
