2015 Foreman 500 EPS problem - Honda ATV Forum
post #1 of 9 (permalink) Old 01-27-2017, 11:30 AM Thread Starter
JimTom's Avatar
I have a 2015 Foreman 500.
I have a tendency to ride through the puddles and water holee on the trail. Nothing major, probably never over the wheels. Never have had any issues.
Recently, 2 things have started happening after riding through a water hole on the trail or if it gets wet.
01) engine light blinks amber and the gear indicator shows a horizontal line. the ATV still runs find unless, you shut it off then it won't start. the gear indicator is a horizontal line. I think it cant determine if its in a gear or not. It won't even start if you hold the right brake , like normal when it is in gear. If I wait awhile , it will start up or if I tow it a ways it will start again.
02) the EPS has stopped working. sometime the EPS light is on and sometimes it is not, either way EPS is not working. A friend of mine looked at it and said the EPS-ECU and the EPS unit is shot from being wet so much and needs replaced. " NOT CHEAP". I don't want to replace them , if they are going to failed again just from getting wet. It seems weird them getting wet , would make them fail, you thing the would be sealed.
If there a way to "water proof" the connections?
I guess I can live with out EPS.
Thoughts / suggestions
JimTom is offline
post #2 of 9 (permalink) Old 01-27-2017, 02:53 PM
will.kostial's Avatar
Liked: 179 times
The engine light and gear shift blink is giving you a code. You have to count the blinks and look it up in a service manual and it will tell you what is wrong..
But.. since it is only happening when you are going threw water? Then I guarantee you have a connection getting wet. Go threw, take all electrical connections apart, make sure they are dry and clean and then put dielectric grease around the edge of them.
2006 Honda Rincon 680 4x4 CAMO
4000 miles and 700 hours
26" Tusk Trilobite HD on 12" STI HD3 wheels
26" Tusk Trilobite HD on stock wheels for plowing
Big Red Final Shifter Mod
Uni Air Filter
Warn Provantage 3500-S
High Lifter Springs
Quad Boss 2" Receiver Hitch
Heated Hand Grips & Thumb warmer
60" Quad Boss Snow Plow
2 Cree Led light Cubes
EBC severe duty brakes
will.kostial is offline
post #3 of 9 (permalink) Old 01-27-2017, 03:41 PM
alloutdoors's Avatar
Liked: 550 times
What do you define as a "puddle"?
2017 Honda Pioneer 500
alloutdoors is offline
post #4 of 9 (permalink) Old 01-27-2017, 06:41 PM Thread Starter
JimTom's Avatar
JimTom is offline
post #5 of 9 (permalink) Old 01-28-2017, 10:28 AM
Liked: 550 times
Hum...I would think it should handle that with no issue. Have you fully charged the battery to see if voltage, etc., may be playing tricks on you? At the same time, I would consider drying the unit real well and connect/disconnect all wiring and assemble with dielectric grease.
post #6 of 9 (permalink) Old 01-28-2017, 02:58 PM
DaBomb6988's Avatar
My Rubicon won't start if the -- is showing in the gear selector. I found rocking it back and forth a bit it will pop into N. I think that's why when you tow it a ways it starts because it gets it back into neutral or a gear. However does the -- blink or stay steady? I believe the blinky indicates an error where the solid is just not in gear. As the others have stated, take the connectors apart and clean the and add some dielectric grease. There is a connector that is mounted low on the frame. I THINK that is the one that goes to the PCM and tells what gear the trans is in.
2016 Rubicon DCT TRX500FA6
Warn 2500lb Provantage
Aluminum Products Skid Plates
1999 TRX300FW
High Lifter Disc Brake Kit
DaBomb6988 is offline
post #7 of 9 (permalink) Old 01-28-2017, 04:36 PM Thread Starter
JimTom's Avatar
Thanks everyone for the suggestions, I will give it a try and report back :-)
JimTom is offline
post #8 of 9 (permalink) Old 01-30-2017, 07:15 AM Thread Starter
JimTom's Avatar
UPDATE:
-We put direct 12v power to the power steering unit, by passing the EPS-ECU unit and the EPS unit didn't do anything. Thinking the EPS unit is burnt up.
- No exactly sure how to check the EPS-ECU unit.
- Over the next day or so I am going to take the all the connectors a part, clean and dry them. Add dialectic grease and see what we get.
JimTom is offline
post #9 of 9 (permalink) Old 01-30-2017, 08:02 AM
ktriebol's Avatar
Liked: 124 times
Have you tried following the EPS troubleshooting procedure that is found in the service manual?
2015 TRX500 Foreman
ktriebol is offline
