2002 Foreman Fourtrax won't take throttle - Honda ATV Forum
 5Likes
  • 1 Post By GirlsRideToo
  • 4 Post By Manny
post #1 of 7 (permalink) Old 06-08-2019, 09:57 AM Thread Starter
rcsmith270's Avatar
I have a 2002 400 with a new carb and a new petcock. starts fine and idles great. It won't take throttle to rev after start unless it idles a while. Carb screw is out 2 1/4 like manual says. Acts like it's not getting a sufficient supply of gas. Fuel line was replaced by a guy that worked on it. Don't get it.
rcsmith270 is offline
post #2 of 7 (permalink) Old 06-08-2019, 09:55 PM
GirlsRideToo's Avatar
Liked: 383 times
When you replaced the petcock did you also clean the gas tank??
Is the new carb OEM? If not, that's likely the problem because it does sound like you still have a carb problem and probably the jet needle.
Please search this forum. There are many threads about the same problem you are having.
Hope this helps you.
mrbb likes this.
GirlsRideToo is online now
post #3 of 7 (permalink) Old 06-09-2019, 07:57 AM Thread Starter
rcsmith270's Avatar
Thanks will do.
post #4 of 7 (permalink) Old 06-09-2019, 08:09 AM
mrbb's Avatar
Liked: 1984 times
also inspect the fuel cap vent too, might be getting vapor lock, if cap is not venting properly and causing fuel flow issue's
mrbb is offline
post #5 of 7 (permalink) Old 06-10-2019, 06:03 PM
Liked: 436 times
Sounds to me like you've either got a leak on the top of the diaphragm cover from improper assembly or a pinhole in the rubber diaphragm itself.
In order for a CV style carburetor to rev up it must be able to create vacuum and lift the slide/diaphragm assembly.
Manny is offline
post #6 of 7 (permalink) Old 06-10-2019, 06:48 PM
Liked: 6540 times
I remember when mine would not rev past half throttle and Manny told me check the diaphragm and sure enough it was split , ran perfect after changing it
fishfiles is online now
post #7 of 7 (permalink) Old 06-10-2019, 08:40 PM
Liked: 1323 times
Do you have the original carb?
I suspect your choke cable is not actuating the starter valve on the aftermarket carb. Aftermarket carbs usually donít fit the choke and or throttle cables.
Check the service manual for carb number
I personally would acquire an oem carb and start over.
Goober is offline
