'06 TRX250TM slipping clutch? - Honda ATV Forum
 2Likes
  • 1 Post By retro
  • 1 Post By retro
post #1 of 6 (permalink) Old 05-22-2019, 08:33 PM Thread Starter
linksg's Avatar
Liked: 11 times
I haven't been able to fully get all the power down on the quad. It's a semi-automatic, non-electric shift, TRX250. I can't find any information on this topic so I'm trying here. Whenever i'm in a high-ish gear and I give it some gas the engine RPMs go up but no power goes through the driveline. Eventually it will "grab" and the engine RPMs go down and I can clearly tell and feel that the engine and transmission are bound. But when ever I gas it, it slips. Happens a lot on hills, and is starting to happen just normally. I have a feeling the "Wight Clutches" are worn or something. The clutch that engages after the engine hits a certain RPM. I don't think its the main clutch pack for shifting gears, but I could be wrong. What is going on?? What can I do to get more power down? Is this common? Because it sure doesn't seem so.
Thanks everyone.
linksg is offline
post #2 of 6 (permalink) Old 05-22-2019, 10:36 PM
Liked: 2974 times
Yep, sounds like the centrifugal clutch is slipping, but it could be the change clutch so inspect those too once you've got the cover off. You may have to replace the drum along with the weights and springs, its probably grooved by now. You won't know for sure until its apart.
For now, try to readjust the change clutch to see if that improves anything. Also make sure that the motor oil you've been using is JASO MA or MA2 approved for wet clutches.
LedFTed likes this.
retro is online now
post #3 of 6 (permalink) Old 05-22-2019, 10:53 PM Thread Starter
linksg's Avatar
Liked: 11 times
So just pull the front cover off and inspect? How big of a job is it to change that stuff out?
linksg is offline
post #4 of 6 (permalink) Old 05-22-2019, 11:08 PM
Liked: 2974 times
Its not very difficult. Getting the nut loose on the centrifugal is easiest using a 1/2" drive impact though.
retro is online now
post #5 of 6 (permalink) Old 05-23-2019, 12:49 AM Thread Starter
linksg's Avatar
Liked: 11 times
Is it reasonably easy to swap those components out without having to pull the motor? That's the big question.
linksg is offline
post #6 of 6 (permalink) Old 05-23-2019, 08:53 PM
Liked: 2974 times
Yeah, but do it the way that you're most comfortable. If I were doing that work I'd yank the motor and do all of the work on the bench. But thats just me... I'm a busted up n' bolted together old fart with a sore back 24/7, bad eyes and bad hands. I look for easiest on the body... and I gotta have lots of light to see with lots of extra space around the subject for my artificial eyeballs headset. I used to be a polar opposite... like a bull in a china shop. No mas tho... :-)
The FSM will clue ya in on all that you'll need as far as tools and the procedures and whatnot.
_Wilson_ likes this.
retro is online now
2000 TRX450FM Build/Mods fishfiles Builds, Projects & DIY 1083 06-14-2019 12:13 PM
Clutch slipping clutch slipping Doctor death Around The Garage 2 05-01-2019 09:13 PM
clutch slipping and high oil pressure...issues or not? skyhiranger Repair & Maintenance 69 08-22-2018 08:29 AM
clutch kit and gear reduction question mudking16 Honda Rancher 19 12-13-2017 07:57 PM
2007 TRX420FE Rancher 4x4 Clutch Slipping Delaina4DCATVPerformance Repair & Maintenance 2 03-26-2016 10:12 AM
