95 fourtrax 300 hanging idle - Honda ATV Forum
post #1 of 2 (permalink) Old 04-08-2019, 10:39 PM Thread Starter
sharkinwagon's Avatar
Liked: 8 times
95 300. Been parked for years. Pulled and cleaned gas tank and carb. New shindy kit in the carb. Carb adjusted to factory settings per service manual. I have a high idle. When I rev it it becomes a hanging idle. (Takes a while to return to the obscenely high idle) Iíve had the carb apart a few times now just double checking my work and canít seem to fine anything. The obvious works as intended. Throttle snaps back as designed, choke raises rpm when on, mixture screw raises idle when I fatten it (back it out)and lowers idle as itís leaned out (crank the screw in)
What am I missing? This isnít rocket science
Now just for fun I moved the e clip up on the needle to the last (highest) position and the idle comes closer to where it should be but chokes and wants to stall if given throttle. What am I missing? Itís gotta be stupid simple. Any suggestions?
Thanks
sharkinwagon is offline
post #2 of 2 (permalink) Old 04-09-2019, 01:51 AM
Liked: 4408 times
put the c-clip back where it goes !. run it through another cleaning. check the diaphragm under the top cap. check to make sure the enrichment valve ( choke valve ) is fully seating when closed. check for a leaking intake boot from being cracked ?. correct air filter ?, oem snorkel stopped up from dirt dobbers ?. idle jet clear ?. plenty of fuel reaching carb ?. 9 out of 10 times, when they run at high idle ?, its either from wrong fuel mixture ?, not enough fuel in carb bowl ?, or an air leak between the carb and intake boot ?.
Ongoing project, 300 fourtrax. SamUK Builds, Projects & DIY 619 06-28-2018 01:44 PM
1988 200 Fourtrax idle and throttle Coelkfreak Honda FourTrax 1 05-30-2018 04:24 PM
clutch kit and gear reduction question mudking16 Honda Rancher 19 12-13-2017 07:57 PM
88 Fourtrax wont idle and we cant figure out why Ram64 Repair & Maintenance 20 03-31-2017 04:15 AM
