'88 350D rear axle shaft binding - Honda ATV Forum
 10Likes
post #1 of 15 (permalink) Old 03-25-2019, 07:26 PM Thread Starter
Duck0fDeath's Avatar
Liked: 270 times
I pulled the rear end assembly from the 88 parts bike I got last week. I was supposed to ship it to someone. When I flushed the diff and checked the ring gear a few days ago while on the bike it seemed to look and turn great. Now that I've got it on the bench the shaft seems to bind. It turns freely in both directions a few inches but then binds slightly. You can keep going back and forth and it frees up in that spot until you go 180 degrees and then it binds again. Sound like wheel bearings? I removed the brake drum already, hoping it was just the brakes. There's no play in the pinion or in the axle shaft at the wheels.
'87 TRX350D
Duck0fDeath is offline
post #2 of 15 (permalink) Old 03-25-2019, 07:58 PM
Liked: 4408 times
open the diff case, have a look at all the teeth on the pinion gear and ring gear, as well as the axle splines. with any luck, all it needs is new bearings.
post #3 of 15 (permalink) Old 03-25-2019, 09:28 PM Thread Starter
Liked: 270 times
I can see the ring gear teeth through the fill plug. They look great. I assumed from that info the pinion gear is likely good too. Went back out to the shop and found that it's not really binding, there's just more resistance than there should be. It spins freely the more you work it. I haven't had to do bearing before on these. Guess I need to tackle it though.
'87 TRX350D
post #4 of 15 (permalink) Old 03-25-2019, 09:32 PM
Liked: 4408 times
you can not see all of the ring gear teeth with the cover on bro ?..only the outer ends you can see through the filler cap. the pinion gear teeth use up all of the ring gear teeth, not just the ends !. this is why I said to pull the case cover, and have a look, besides, if your gonna replace the bearings ?, you will need to do this anyway :-).
post #5 of 15 (permalink) Old 03-25-2019, 09:33 PM
Liked: 4408 times
before you go tearing any bearings out ?..MAKE SURE YOU CAN GET A REBUILD KIT FOR IT !!!!!!.
post #6 of 15 (permalink) Old 03-25-2019, 09:49 PM
Liked: 3221 times
My .02 cents... I think its probably a standard case of factory axle runout. Everyone of those axles are slightly bent from the factory. Lay the axle in V-blocks and rotate it by hand and you'll see what I mean. I've never seen an SRA Honda axle that didn't measure having at least .020" of runout and most of them measure between .025" & .030" out.
Other than that it could be a dry wheel bearing contributing. If you suspect a dry bearing you can hit it with a heat gun or a hair dryer to find out... see if that fixes it. If so, repack and ship. :-)
post #7 of 15 (permalink) Old 03-26-2019, 05:31 AM Thread Starter
Liked: 270 times
You can repack those bearings? They look like the sealed kind from the pictures I'm seeing.
retro likes this.
'87 TRX350D
post #8 of 15 (permalink) Old 03-26-2019, 08:34 AM
Liked: 3323 times
I wouldn't put new bearings in there if there isn't play in the ones in there now. Pull the diff, unbolt the case halves, and pull the diff in two (make sure you keep up with the shims and keep them on the ring gear on the same side they're on now).
Clean out the casings and lube those bearings. They've probably been setting up for months if not years. Lube them up good with some gear oil, and grease the bearings in the brake housing and left axle tube, and put it back together. Those factory bearings are better than anything else you're going to get, so if there isn't play in them, clean them out and then re-lube them up and get them spinning freely, and leave them in there.
retro likes this.
Jeepwm69 is online now
post #9 of 15 (permalink) Old 03-26-2019, 09:48 AM
Liked: 4408 times
you don't repack differential bearings bro, they must be open, and ride in gear oil at all times :-).
Jeepwm69 likes this.
post #10 of 15 (permalink) Old 03-26-2019, 11:00 AM
Liked: 3323 times
Yep! But you can flush them (and the diff housing) out good and then put some clean oil in them and I'll bet they roll smoother!
But do repack the brake housing bearing and the left tube bearing with grease.
shadetree and retro like this.
300 rear ends and a 350D pinion bearing question Jeepwm69 Repair & Maintenance 6 11-06-2017 06:19 PM
TRX250EX axle shifted?!?!? Need Advice VIRDOC Repair & Maintenance 6 09-21-2017 06:25 PM
Trx350d locker 4trax1986 Performance Modifications 35 06-24-2017 02:11 PM
Fourtrax 350 rear axle shaft mitchellkend Honda FourTrax 7 05-15-2017 12:41 PM
2005 Rancher Leaking left Rear Axle ph_knox Honda Rancher 13 12-22-2016 10:59 AM
