86 TRX350A Restoration - Page 4 - Honda ATV Forum
 159Likes
post #31 of 118 (permalink) Old 04-13-2019, 08:41 PM Thread Starter
Liked: 1514 times
Removed all the fenders and got a good look
Dash panel harness worn thru caused by that monster homemade front rack. Every sub harness is damaged in some way. Hacking from the aftermarket key switch resulted in some wires left unplugged.
Set the valves — first time for me ya know!! –so easy but i want those adjuster tools. one of the valve adjusters is slotted and the others are square?! Circled in yellow is this typical???
Also adjusted the decomp lever now she doesn’t kick back.
Oil leak is caused by a stripped tappet cover bolt so i bought a helicoil kit. The other bolt holes have helicoils already
Tomorrow i will wash down the frame so i can see where the rust is. This darn thing looks like cows been rubbing on it plus covered with webs from webworms. I may have to do some spot rust treatment on the frame like @GirlsRideToo
Oh yeah the right front wheel has a small amount of play in it. Like the axle nut is loose. Bearing probably?
ID:	135516   Click image for larger version
ID:	135518   Click image for larger version
ID:	135520   Click image for larger version
ID:	135522   Click image for larger version
retro and GirlsRideToo like this.
Goober is offline
post #32 of 118 (permalink) Old 04-13-2019, 09:35 PM
Liked: 3222 times
Those valve lash adjusters should all be square headed, but you knew that already. Its disappointing to see all of the wiring torn up like that, especially that fuse box sub-harness. But that bike will be in great shape once those are replaced... Ya can't be lucky every time I guess.
I still admire the ageless durability of those old tanks. They still look so darn repairable... every one of them!
Goober likes this.
retro is online now
post #33 of 118 (permalink) Old 04-21-2019, 07:53 AM Thread Starter
Liked: 1514 times
I replaced the fuze box harness–scavenged minor hardware from 3 others to get a complete one!
Replaced the drive shaft cover and the shifter yesterday–installed all proper bolts. Broke loose the exhaust pipe nuts and pipe protector bolts–cleaned threads. I use antiseize on them all.
Cleaned and inspected the dash indicator and main harness. You can see in second pic that mice have chewed the main harness where it plugs into the fuze harness. Need to dress all the new main harness connectors with dielectric grease.
Put together a complete battery box from parts I’ve collected over the years. Counted the number of TRX350 cannibalized sofar to make this build — 16.
ID:	135856   Click image for larger version
ID:	135858   Click image for larger version
ID:	135860   Click image for larger version
ID:	135862   Click image for larger version
retro and Duck0fDeath like this.
Goober is offline
post #34 of 118 (permalink) Old 04-21-2019, 08:23 AM
Liked: 4408 times
haha...my bud is tempting me to restore another one of these, but sheshh..like you, it would take a ton of these bikes to make one good one !..lol.
Goober likes this.
post #35 of 118 (permalink) Old 04-24-2019, 06:52 PM
Duck0fDeath's Avatar
Liked: 270 times
That's been my strategy.
I have 7 frames and nearly 3 complete bikes in addition to my keeper rig. About to put one together for the wife finally. Still need to keep an eye out for some solid blue plastics for it. I have a line on some but they're spendy.
Goober, _Wilson_ and retro like this.
'87 TRX350D
Duck0fDeath is offline
post #36 of 118 (permalink) Old 04-24-2019, 07:14 PM
Liked: 4408 times
front tires are on backwards on the blue one !..lol.
post #37 of 118 (permalink) Old 04-24-2019, 07:38 PM
KoolBreeze's Avatar
Liked: 68 times
Sho'is! Easy to do if you're not paying attention.
Dang Duck, you got a shop full of them. My wife might shoot me if I brought home another one. Says every time she sees me working on it, it's costing her money.
Goober likes this.
KoolBreeze is offline
post #38 of 118 (permalink) Old 04-24-2019, 08:02 PM
Liked: 270 times
I picked that blue bike up on Saturday. Dude swapped wheels and tires around before I showed up. It's got four front wheels. I can't even get a wrench on the shock bolts with the wheels on in back Thing was armored out with steel mesh lined racks and rear fender guards that ran down to the floorboards and welded up. I spent two nights cutting them off the stock racks.
'87 TRX350D
post #39 of 118 (permalink) Old 04-24-2019, 08:15 PM
Liked: 270 times
Sorry to be hijacking your thread, Goober. Hey, I picked up an 86 a couple weeks ago. Let me know if you need anything I might have. I'd be happy to make a contribution to your build. Hopefully something light, for shipping concerns
Goober and retro like this.
'87 TRX350D
post #40 of 118 (permalink) Old 04-25-2019, 06:55 AM Thread Starter
Liked: 1514 times
Ima show this picture of your herd to my spousal unit lols
retro likes this.
Goober is offline
