1986 FourTrax 250 Gear Grinding - Honda ATV Forum
 3Likes
  • 1 Post By jczepil
  • 2 Post By Jeepwm69
post #1 of 8 (permalink) Old 11-02-2018, 08:51 PM Thread Starter
jczepil's Avatar
Hey Guys,
Quick question for you, I hear a grinding in the axle/driveshaft location when I'm in reverse on my 1986 Honda Fourtrax 250. It sounds as if the gears are grinding and it gets worse when I'm turning and in reverse. Any idea of what could be wrong here and where I should start looking? Don't see to have any issues when going forward......
Thanks,
Jeff
Goober likes this.
jczepil is offline
post #2 of 8 (permalink) Old 11-03-2018, 08:13 AM
Liked: 1421 times
It’s a 2wd right? First thing I would check is the diff oil level. Maybe just empty. If full, you might lift it up and see if you have any slip in the drive line.
If you change the oil you might find chunks of metal in there. If so your pinion or axle or both are worn. Hopefully just the axle I wouldn’t drive it any more until you pull the axle.
Not fam with this rig but I’m sure the service manual has a troubleshooting guide for this
Goober is offline
post #3 of 8 (permalink) Old 11-03-2018, 10:45 AM Thread Starter
jczepil's Avatar
Goober,
Thanks for the advice. I have it parked now and I'll tear it apart and see if its the axle. It sounds like a ring/pinion issue the way it acts, but I hope it's just the axle. Any idea where to get a replacement ring/pinion for these old ATV's?
Jeff
jczepil is offline
post #4 of 8 (permalink) Old 11-03-2018, 11:20 AM
Liked: 1421 times
You can click my parts links and see if Rocky Mtn has them (under Final Driven Gear IPB); then use the part number to search fleabay occasionally NOS units pop up.
By that time you should be confident in the type of parts you need. Suspect and Check also too the other components like drive shaft but I think you’re looking in the right area.
Goober is offline
post #5 of 8 (permalink) Old 05-08-2019, 08:31 PM Thread Starter
jczepil's Avatar
Hey Guys,
Finally got around to taking the rear end apart and the pinion bearing in the rear end was completely failed. It looks like the pinion is actually ok, so I just bought a new bearing set for the rear end.
Anyway, while disassembling it looks like I need a special tool to remove the pinion from the housing. I'll attach a picture so you guys can see what I mean.
Any idea where to get this tool?
Thanks,
Jeff
jczepil is offline
post #6 of 8 (permalink) Old 05-09-2019, 08:44 AM
Liked: 3275 times
Where are you located Jczepil? You need a pinion nut socket, although a properly sized length of square tubing will usually work.
misterclean59 and _Wilson_ like this.
post #7 of 8 (permalink) Old 05-09-2019, 10:16 PM Thread Starter
jczepil's Avatar
Jeep,
I'm up in British Columbia, Canada. Any help would be appreciated.......
If a piece of square tubing would work than I can try that, but would prefer to get the correct socket if possible.
Thanks,
Jeff
jczepil is offline
post #8 of 8 (permalink) Old 05-13-2019, 08:57 AM
Liked: 3275 times
Well if you were close I was going to let you borrow one, but I'm in Arkansas. LOL.
https://www.ebay.com/itm/Honda-ATV-P...ox!72360!US!-1
