Carburetor Talk 101 - Page 3 - Honda ATV Forum
 2Likes
post #21 of 72 (permalink) Old 07-20-2009, 08:13 PM Thread Starter
Saber6's Avatar
Thats close LMFAO!!
http://www.oilburners.net/forums/cus...atar1326_2.gif
BOOB man - "Brotherhood of Oil Burners" Local 715
Sometimes I wonder,.."Why is that Frisbee getting bigger,..? then it hits me,...
Saber6 is offline
post #22 of 72 (permalink) Old 07-22-2009, 11:12 PM
joshm725's Avatar
Unhappy carburetor problem?
i have a 1985 honda 200x...it idles just fine. it wont rev up though...i hit the throttle ever so slightly and it stalls out sometimes making a backfire or popping noise....although sometimes if i let it idle for like 5 minutes i can rev it up real quick once or twice and it dies and does what i stated above......would that mean its starving for gas? or something else?
joshm725 is offline
post #23 of 72 (permalink) Old 07-23-2009, 09:22 AM
Liked: 411 times
Check your air filter and hoses for restrictions also check you fuel lines one may be crimped you have enough fuel to idle but when you apply more throttle youo demand more fuel and it's starving out. check your fuel bowl for sediment, water, ECT take out the jet and clean it make sure the orfice isn't restricted. and check your intake hoses for cracks.
TRX2fiveO is offline
post #24 of 72 (permalink) Old 07-23-2009, 09:37 AM
joshm725's Avatar
i cleaned my jets,made sure the gas line was open,my air filter isnt hooked up right now so i can work on the carb easier,and the bowl had no water or sediments in it at all...and it still does what it was doing before?anything else that could make it do that?
joshm725 is offline
post #25 of 72 (permalink) Old 07-23-2009, 10:39 AM
Liked: 411 times
It could possibly be a timing issue
post #26 of 72 (permalink) Old 07-23-2009, 01:16 PM
joshm725's Avatar
thanks ill check it out someone just stopped by my house he said it sounds like my main jet...but i dont know how i've checked it three times and so has one of my friends it looks clear.
joshm725 is offline
post #27 of 72 (permalink) Old 07-23-2009, 02:55 PM
Liked: 411 times
thats easy just pull it out and stick a needle through the hole or something that is just as small as the hole put it in and try it..... then check your timing if it still does it. do you know how if not i may be able to help you or Tomgodd.
post #28 of 72 (permalink) Old 07-23-2009, 08:13 PM
joshm725's Avatar
Unhappy carburetor
yeah i checked it its okay also recleaned it just in case..and still didnt work..and i have no idea about the timing chain..dont even know how to access it..but would it be the timing chain because if i turn the idle screw in the idle will go up and i can turn it in all the way and it basically revs the engine all the way but thats not even opening the slide all the way its only moving it partially up..and sometimes the rpms go up by itself and i turn the idle screw down and it idles just fine (but still cant rev it up).....ive been working on it three days now and cant get it to do nothing but idle cant rev it but like i said before if i ever so lightly press the throttle it revs up really fast at high rpms and my slide isnt even opened up all the way..so im really confused im used to working on threewheeler engines but this one has me stumped.
joshm725 is offline
post #29 of 72 (permalink) Old 07-23-2009, 09:08 PM
joshm725's Avatar
Red face carb
nevermind i think i solved it....the guy i bought the 200x off of stripped the carb of some parts and i had looked at a manual and its missing quite a bit of stuff thats not noticable unless you look at an identical carb thanks for the help ill keep ya posted if this is the problem or not but im pretty positive it is..if not then it has to be the timing chain and ill be back if it is....thanks for the help though trx2five0
joshm725 is offline
post #30 of 72 (permalink) Old 07-24-2009, 04:18 PM Thread Starter
Saber6's Avatar
After reading all the posts im thinking you have some issue with the carb not timing.
Saber6 is offline
