Which ratio for my application - Page 2 - Honda ATV Forum
Gear Reductions Discuss and post information on gear reductions.
 12Likes
post #11 of 20 (permalink) Old 11-16-2018, 03:19 AM
Liked: 6314 times
When you send the cores back , be sure to get the washer off the inside back of the primary gear , it will sometimes stick to the gear , if you don't install it on the new primary then you will get a whinning sound , some people say it doesn't matter if you ude the washer or not , some do ----I got 54% in my 92 300 with 27 outlaws and 54% and 54% with 26's on the other and 54% is a bit much , but plans are to up the tire size in the future ---I believe I read RBM recommends 18% with 26's
fishfiles is offline
post #12 of 20 (permalink) Old 11-16-2018, 03:25 AM
Liked: 6314 times
Something else I might pass on , I figured out that when you get the reduction , you will be doing more rpm's then what you were use to using , no tach so you don't see it , you can hear it but don't realize it , and you wind up running the bike hard , change your riding style and learn thumb control
post #13 of 20 (permalink) Old 11-17-2018, 09:42 AM
SamUK's Avatar
Liked: 1957 times
Originally Posted by misterclean59 View Post
Great idea. i was thinking that 1st and maybe 2nd would be worthless with stock tires and wheels. 54% would give you less than half of your top speed in high gear...........maybe 20 mph at 6000 rpm's?
31 mph taken by GPS with a Ricks CDI was what I got top end.
98 300 Fourtrax 4x4
2004 Foreman 450S
SamUK is offline
post #14 of 20 (permalink) Old 11-20-2018, 11:16 AM
misterclean59's Avatar
Liked: 526 times
Wow, That's much faster than I would guess. So the top speed is 63 MPH with stock gearing? We are talking about 54% reduction correct?
misterclean59 is offline
post #15 of 20 (permalink) Old 11-20-2018, 12:39 PM
Liked: 6314 times
Maybe he is talking kilometers per hour ----- I need to clock my 300's and see what they will do , every ride I take in the woods I have a GPS on the handle bars and never once I have looked at the speed , with my bad eyes I wonder if I even could see it while running wide open
post #16 of 20 (permalink) Old 11-20-2018, 01:34 PM
mac102004's Avatar
Liked: 2010 times
You are forgetting that changing tire size will effectively change your final ratio as well. A top speed of 31MPH with a 54 and 28-30 tire is a lot different than what the top speed would be on stock 23/24 tires and that same 54% GR.
_Wilson_ and SamUK like this.
2015 Honda Rubicant FM7
- 28" Mud Bugs
- Powermadd Handguards
- ODI Grips
- 31x11" Outlaws
- NPP Dual Dominators
- ECM Reflash
- TheBOM Mag+ Cams
- TwinAir Air filter
- Delrin Motor Mounts
- Aluminum Valve Covers
- Gorilla Through Shaft
- TigerTail
mac102004 is offline
post #17 of 20 (permalink) Old 11-21-2018, 03:12 AM
Liked: 6314 times
Mac , you would be the guy I think most informed on this question , a 2000 TRX450S , with 35% reduction and 33 inch tires , would the ratio of the tires at the ground be good ? think I would be better suited with 31's or 32's ?
post #18 of 20 (permalink) Old 11-24-2018, 10:28 AM
SamUK's Avatar
Liked: 1957 times
Generally speaking fish anything above a 31” tyre is 72% reduction and up to pull tyres in all conditions. If your water riding in that sloppy peat bog stuff I’d say 31’s but even then you may well get bogged down.
Interested to hear @mac102004 opinion.
98 300 Fourtrax 4x4
2004 Foreman 450S
SamUK is offline
post #19 of 20 (permalink) Old 11-24-2018, 03:55 PM
Liked: 6314 times
I was wondering what happen to you Sam , I got thrown off face book , didn't take long , maybe 2 weeks max , I will never go back
post #20 of 20 (permalink) Old 11-24-2018, 10:43 PM
mac102004's Avatar
Liked: 2010 times
I wouldnt run anything bigger than 30s with a 35%, even then with an aggressive enough tire youll find mud that will stop the tires. 53% is about ideal for 30-31s, maybe 32s depends on stock engine or not and again, how bad the mud is. 33s Id be running a 69% for sure. I know someone makes a 100% GR for them, so if you really want to be sure 33s arent going to stop moving....
Of course with the right engine mods you can make up for the gearing or lack thereof. Big bore kit, mild stroker, cam, port and polish, all that fun stuff....probably get away with that 35% and 33s.
It would sure be nice if guys would start focusing a little more on portals or even planetary reductions at the wheels on the Hondas, 300 and Foremans alike. Big GRs in the motor are putting a lot more stress on the transmission, diffs, axles etc. Moving that reduction as far as possible down the driveline really helps save a lot of components further up. I think with thats currently available on the market if I wanted a big lift and GR for some 33 or larger tires Id be looking very hard at adapting some of the current off the shelf portal boxes onto a Honda. Of course the Renegade they already sell boxes for.
fishfiles, Menard_LaPue and retro like this.
- 28" Mud Bugs
- ODI Grips
- 31x11" Outlaws
- ECM Reflash
- TheBOM Mag+ Cams
- TigerTail
Go Back   Honda ATV Forum > Honda ATV Technical Discussions > Gear Reductions
