400ex 440 build - Page 4 - Honda ATV Forum
 4Likes
post #31 of 38 (permalink) Old 02-21-2016, 08:13 PM Thread Starter
DoubleB's Avatar
All done. Added a manual cam chain tensioner and a trans oil cooler from a gmc pickup as an additional oil cooler. Fixed the cooling issues altogether.
ID:	34738   Click image for larger version
DoubleB is offline
post #32 of 38 (permalink) Old 02-22-2016, 05:35 PM
sandman1454's Avatar
I have a 05 426 with a 45cr carb on it with doul pips keeps blowing head gasket's
sandman1454 is offline
post #33 of 38 (permalink) Old 02-22-2016, 06:08 PM
SlammedRanger's Avatar
Liked: 1323 times
Welcome to the forums! I suggest you start your own thread to get the most answers. As for your head gasket issue. Did they bore the stock sleeve out to a 426 or re-sleeve the cylinder? Do you have gt thunder hd head studs? And are you using a high quality mls (multi layer steel) headgasket? If yu answered no to either of the last 2 questions there is your problem right there.
07 416ex
To many mods to list in signature(ran out of space lol)
Check out garage for full list
SlammedRanger is online now
post #34 of 38 (permalink) Old 02-22-2016, 07:37 PM Thread Starter
DoubleB's Avatar
Yep....you need gt thunder head studs and cometic multi layer head gasket. Now you'll need to make sure all of your mating surfaces are dead flat as well.
DoubleB is offline
post #35 of 38 (permalink) Old 04-29-2016, 11:55 PM
Uberbricky's Avatar
Liked: 17 times
How has the 440 been treating you? Any issues yet? I can grab one locally for cheap, was planning on a similar build to yours....
This is my 400EX. There are many like it, but this one is mine.
Uberbricky is offline
post #36 of 38 (permalink) Old 05-01-2016, 10:22 AM
Rurouni20xx's Avatar
Liked: 201 times
nice double cooler and oversized oil tank, the oil tank alone is an almost must have investment on any modded 400ex.
Download Factory Service Manuals Here: https://www.hondaatvforums.net/forums...downloads.html
Rurouni20xx is offline
post #37 of 38 (permalink) Old 05-01-2016, 12:13 PM
Slam1's Avatar
Liked: 29 times
He should be able to keep with Dad's 450 in the woods and maybe in the open sections depending on tire selection and rider ability. P.S. I live in Fl. and never had an overheating issue. Did blow some head gaskets but went to solid copper and have had no problems. I also run Rotella T oil with no issues in seven years.
Former SSQSA Trail Boss
99'-05' 400/450 Woods Killer
Heavily Modified
89' TRX 300 4x4
unmodified
00' Blaster (wifes)
Medium Modified
06' Extreeme Typhoon 90
(Grand Daughters)
Slam1 is offline
post #38 of 38 (permalink) Old 08-07-2016, 09:16 PM
dieseljeeper's Avatar
on my ex I used a moose racing carb kit that supplies a slotted mixture screw. I have a motion pro angle driver but will not clear the starter. I stuck a slotted bit in a piece of 1/4" fuel line about 8"long and can adjust it from underneath. Redneck engineering on an Amish budget
dieseljeeper is offline
