My New Project.... - Page 4 - Honda ATV Forum
post #31 of 35 (permalink) Old 11-21-2011, 06:25 PM Thread Starter
dirtguy25's Avatar
Originally Posted by Tino55 View Post
well where are you getting the frame from. And all the other parts.
I've got a 2003rancher TM that the crankshaft went bad in. I've got the motor completely tore apart. The last part I needed to order was the crank. I was getting ready to order it a few days ago when I came across the 2000 model rancher TE. I figured I couldn't go wrong for 275. The odometer on the TE reads 4223 miles. I already had the motor out of the TM , so all I had to do was change out the wiring harness and all of the component's that the TE had that the TM didn't.
2003 rancher 350 - 2002 trx 300ex - 1999 ltf 300f - 1986 trx 70. - 1984 atc 70-
dirtguy25 is offline
post #32 of 35 (permalink) Old 11-21-2011, 06:32 PM
cmanningjr's Avatar
Liked: 423 times
Good motor for $275 is a good deal anyway you look at it...
cmanningjr is online now
post #33 of 35 (permalink) Old 11-21-2011, 08:32 PM Thread Starter
dirtguy25's Avatar
The beautiful part about it is I've already got everything to do a rebuild on this atv when it needs it. I bought a new piston kit, valves, gasket kit, valve seals, cam chain, and had the cylinder bored for the engine out of the TM.
post #34 of 35 (permalink) Old 11-22-2011, 01:06 AM Thread Starter
dirtguy25's Avatar
The transformation is done. I now have a rancher TE! The only problem I had was with the wiring harness. The small plug that goes to the ecm and the plug that goes into the regulator/rectifier are the exact same size. They are Eben the same length comming out of the harness.the only difference is one has 5 wires and the other has 6. Well I got them wrong the first time. Hooked up the battery and instantly blew the 30a motor fuse! It took me a minute to figure out what I had done wrong, but I'm just glad it blew the fuse before it had a chance to do any damage.
post #35 of 35 (permalink) Old 11-22-2011, 04:04 PM
Liked: 436 times
ahhhh man no pictures??? lol good job man!
Manny is offline
