Hydraulic plow lift.. - Page 2 - Honda ATV Forum
post #11 of 13 (permalink) Old 11-22-2011, 08:18 PM Thread Starter
hickory's Avatar
Originally Posted by BobbyJ View Post
Use the electric Linear actuators they don't cost as much and you can get to length needed, lift and dump with down pressure.
That was a idea I thought of early on. But heres the thing I have a 12 volt hydraulic pump and 4 cylinders that were free. I have priced some of those actuators and they get pretty expensive.
hickory is offline
post #12 of 13 (permalink) Old 11-22-2011, 08:20 PM Thread Starter
hickory's Avatar
Originally Posted by bobs330 View Post
Only problem with being forced down is increased wear on the moldboard.
I also thought about that but if you seen they pile of steel I have at my disposal you wouldnt worry about a little extra wear on the plow its self.
hickory is offline
post #13 of 13 (permalink) Old 11-29-2011, 08:49 AM Thread Starter
hickory's Avatar
Well I have been gathering things up to rework my plow mount so I can make it hydraulic and Im pretty sure I have every thing I need to build it. I also remembered that I have a old Ariens lawn tractor out at my Grandpas place that has most of the stuff I need to build the 3 point system. I need about 10 feet of heavy wall square tubing to build the 3 point and I should have every thing I need. I had also been looking at these rough cut pull behind mowers and trying to figure out the best way to build one but that has been solved.... I got to work this morning and someone had hauled 1 in for scrap now all I need is a motor. Also I have been thinking about making it hook up to the 3 point like a brush hog for a tractor. What do you guys think would be better Pull behind or 3 point???
hickory is offline
