DIY Cooling Fan Gizmo - Page 2 - Honda ATV Forum
 181Likes
post #11 of 121 (permalink) Old 03-27-2019, 06:05 PM
Liked: 1273 times
Ok now Shade and i are gonna crack a cold one while Retro and Wheelsquad discuss Fourierís and Fickís Laws of momentum transfer
Goober is offline
post #12 of 121 (permalink) Old 03-27-2019, 07:26 PM
_Wilson_'s Avatar
Liked: 1618 times
Ya got me in a bit over my head
Ya right! ^^ . I don't think so...I'm looking forward to what you build in the future...
fishfiles and retro like this.
_Wilson_ is offline
post #13 of 121 (permalink) Old 03-27-2019, 09:26 PM Thread Starter
Liked: 2753 times
The cold ones sound interesting, Fouriers & Ficks sounds like an upscale NY dept. store to me tho? :-)
I mocked up the gizmo today using 3.65k ohms resistors (can't find any 5k in my bins) on the left side, following my hunch. It works good with those 3.65k's in there, but I think it will work even better with 10k ohms resistors put back in there.
It is overly sensitive during calibration right now IMO, using those 3.65k ohms resistors in there. I'm gonna swap the 500k ohms Hysteresis trimpot out for a 1 Meg ohm trimpot too, to help relieve some of the over-sensitivity on that function of the circuit. So I'll test again tomorrow and hopefully, get started on adding a coupla' mo' ideas to it.
No pics taken today, sorry. I ran out of time. I'll get a coupla' pics of the mockup tomorrow.
fishfiles, Goober and _Wilson_ like this.
post #14 of 121 (permalink) Old 03-28-2019, 08:40 PM
wheelsquad's Avatar
Liked: 558 times
Originally Posted by retro View Post
I'll mock this up on a perf board this week an' see what can be learned. Any suggestions? Requests? Critiques? :-)
Don't forget the fail-safe feature where the fan will actually run when the sensor goes bad.... vs fan never coming on, how Honda has it.
2004 TRX400FA (Rancher 400AT)
MotionPro twist throttle kit
rear rack wheelchair carrier
2011 Grizzly 450 EPS
wheelsquad is offline
post #15 of 121 (permalink) Old 03-29-2019, 01:11 AM Thread Starter
Liked: 2753 times
Yeah, matter of fact I was thinking about that feature today so I'm glad that you mentioned it. We have the idiot light in the display that will likely never, ever come on. So, if we can design the gizmo so that the fan starts if/when the sensor fails high out of range... AND we can start the fan if the oil sensor wire ever gets unplugged/ripped in half by a stick or something...? Should we tie that over-temp LED into that half of the device, so that the idiot light comes on whenever the sensor fails high, or it gets unplugged?
We can take advantage of that light somewhere else besides an overheat condition I feel, because the primary function of the gizmo should already eliminate any overheating by its sensitivity and precision.
Of course, the oil cooler could get plugged up with mud or the cooling fan motor could fail or blow a fuse, causing an overheat. Unless we add a thermister onto the cooler to monitor cooler temps and add a hall-effect tachometer circuit to the fan motor... :-)
Think about it... lets bounce some ideas.
So far I think we are gonna have to monitor the ambient air temperature, because sub-zero air temps would false-trigger our sensor failing high feature. Complexities are imminent. :-)
EDIT:
Actually we might be able to turn that over-temp LED on if the motor overheated too, so don't rule that possibility out just yet.
post #16 of 121 (permalink) Old 03-29-2019, 01:41 AM Thread Starter
Liked: 2753 times
I promised a pic of the mockup so here it is. As you can see I am using a Red LED (its lit in the pic) to indicate to me when the transistor turns on/off, rather than tripping a fan relay at this point. I'm also using a 5k ohms pot in place of the oil temp sensor to speed up testing. Since we've already learned our operating resistance range from the veggie oil tests we can quickly dial in our targets using the pot.
I didn't get to spend any time on it today cause universe made other plans. I'll try again tomorrow. I am putting together a short list of parts that we might need, probably order those up this weekend.
post #17 of 121 (permalink) Old 03-29-2019, 05:17 AM
Liked: 6286 times
"A" cold one is a teaser -------- I don't drink during the week , unless it is a special occasion , but tomorrow is Saturday and I will be on a mission to destroy a 20 pack of Coors Lite
Goober, _Wilson_ and retro like this.
fishfiles is online now
post #18 of 121 (permalink) Old 03-29-2019, 06:11 AM
wheelsquad's Avatar
Liked: 558 times
Yep exactly what happened to mine, sensor wire came unplugged, my oil cooler may have been restricted some, it was really hot out and I was in slow going in old pasture bogs, but since the default fail from mode from being unplugged was to not run the fan, and oil temp light also doesn't come on then, mine got REALLY hot before I realized it.
retro likes this.
post #19 of 121 (permalink) Old 03-29-2019, 06:14 AM
Liked: 1273 times
Canít drink all day unless you start before breakfast.
_Wilson_ likes this.
Goober is offline
post #20 of 121 (permalink) Old 03-29-2019, 06:45 AM
wheelsquad's Avatar
Liked: 558 times
@retro, I'll try and think of ideas to best utilize the idiot light. But I'm thinking I like your idea most for having it come on if there is an error in the fan or fan circuit itself. Since it should be obvious with the gizmo in place of a temp sensor or wire issue with the fan running continuously.
does this fourtrax have oil cooling or fan cooling please read iijason Honda FourTrax 18 09-26-2017 06:02 PM
