DIY Cooling Fan Gizmo - Page 15 - Honda ATV Forum
 294Likes
post #141 of 174 (permalink) Old 06-02-2019, 07:33 PM Thread Starter
Liked: 2933 times
Progress report 'n pic dump... :-)
I finished the oil temp sensor that was dunked into JB-weld yesterday.
The PCB is ready for soldering the wires onto it and mounting it inside the enclosure back. That'll be glued into place on the four mounting studs using JB-weld. I put a Bournes 25 turns, 10k ohms trimpot on this one (was 25 turns, 5k ohms on previous builds) to learn whether it provides easier and faster calibration or not. I suspect that it'll calibrate the same though... but if its any faster to get dialed in I intend to use 10k trimpots from now on.
The two harnesses are fitted into the enclosure back. The JB-weld wire knot will be cured enough tomorrow, so that I can cut that temporary ziptie clamp outta there and mount the PCB. The button strip holes are already dremel-ed out on the cover, so once the PCB is mounted I can dremel out the display window and drill the LED indicator light hole. The grey tinted window and buttons frame is completely fabbed up and ready as well. Fingers are crossed... just one more window to cut out and it'll be ready to calibrate in hot oil. It looks fabulous so far!
And... I got the power supply board all built, mounted the 40 amp relay inside the enclosure and began to wire it in. I stopped right there cause I have a question... The first build has those harnesses coming into the box on the side, opposite the 40 amp relay. Since we plan on mounting this box under the winch plate... Do you think we should run those harnesses into the end of that box @wheelsquad? Give us a straight line shot for the harnesses aiming toward the steering head area? It doesn't matter really, but might make for a cleaner looking install?
I gotta make a list and place some orders for parts and materials that I am running out of, and for some parts that I am changing out for the better. So this gizmo won't be finished until next weekend, more'n likely. I'll ship it out to ya soon as I can. We can salvage a few components outta that first build so it won't be a total loss... it's learnin' costs. Prototypes are usually junk an' I shoulda know'd to hold onto that bugger.
ID:	137024   Click image for larger version
ID:	137026   Click image for larger version
ID:	137028   Click image for larger version
post #142 of 174 (permalink) Old 06-03-2019, 02:02 AM
wheelsquad's Avatar
Liked: 597 times
Originally Posted by retro View Post
This is the clamp bracket I made for this gizmo @wheelsquad. Whadd'ya think? Shall we throw it back, or try it? The bracket might provide us with a Plan B if that clamp don't work... :-)
I think that bracket will work great as you have it, just like the first version only better!
Your plate idea should work well for others' general applications. I have used same the mirror mounts @fishfiles mentioned. They're actually what I used to mount my light bar to my handlebars. I like them a lot, but need to think of a low profile way to attach the stud/bolt that threads into them to your plate. Maybe just drill a hole in the flat part after the bend and a short bolt into the bracket? What would be a little more ideal is a bracket that has 2 holes so that the plate can be attached by 2 points and not be prone to pivoting around that a single point would have.
For those wires coming out the end, I doubt anybody is going to notice the looks of anything under my winch plate, so that's no reason to. Heck if you saw the rest of the DIY stuff done to my Rancher, the more redneck looking it is the more it will fit in. But straighter shot and less sharp bend in the wires is probably enough reason to put them in through the end though, for reliability.
And haha, no worries and I'm sure USPS doesn't mind the business. It was good to know in advance your little fab'd plate clamp is gonna work great.
2004 TRX400FA (Rancher 400AT)
MotionPro twist throttle kit
rear rack wheelchair carrier
2011 Grizzly 450 EPS
wheelsquad is offline
post #143 of 174 (permalink) Old 06-03-2019, 10:15 AM Thread Starter
Liked: 2933 times
Ya ok, I guess we'll run with that aluminum bracket and see what happens. I have a pair of those handlebar clamps that @fishfiles posted which I looked at while trying to decide what to do there. If one of those clamps were flipped over, a hole drilled in the bracket and with a lil' filing on the bracket so it fit the clamp shape like a key, I think one short bolt would hold it without any risk of twisting. The filing-fit step could provide an ideal tilted-inward viewing angle from the bar too, I think.
Ideally we'd like that mounting bracket to disappear once its on the bike. Anyway, I mounted the bracket low on the gizmo thinking along those lines.
I'll run the harnesses into the end of that relays box this time to see how it works on your bike. On my bike those wire sheaths could have been routed either way, so I'm guessing the fit on your Rancher will be the same.
post #144 of 174 (permalink) Old 06-04-2019, 04:11 AM
Liked: 6534 times
Retro ,what are the width and length of your Gizmo controller , I am looking at the spot between the GPS and the toggle switches as being a good location
retro likes this.
fishfiles is online now
post #145 of 174 (permalink) Old 06-04-2019, 10:33 AM Thread Starter
Liked: 2933 times
That'll probably work fishfiles. These specs for the Bud Industries HH-3641 are from the datasheet:
Enclosure Dimensions:
69.5mm x 50.5mm x 21mm (2.736” x 1.988” x .827”)
I have a junker enclosure that I made a mistake on and ruined. I can send it to ya if ya'd like...? It might help ya come up with a mounting bracket idea that provides a clean, tight, integrated looking install. PM me or shoot an email...
Also a heads up... I am looking into the feasibility of adding a 4th button onto the control unit that allows switching back 'n forth between two different oil temp sensors on the fly.
The default would be the sensor in use in the bottom of the sump. The alternate sensor could be monitoring from the oil hose exit from the motor... or more'n likely the other end of that oil hose entry into the oil cooler will be a more practical location. One of those alternate sensor locations should provide motor oil temp while it is at its hottest state.
The thermistors that I have been building sensors with are interchangeable... that means every sensor is designed to be switched in-circuit without having to recalibrate the measuring circuit.
https://www.littelfuse.com/products/...s/ps103j2.aspx
They boast precision accuracy to be maintained within +/- 0.1 degree C through 70 C, between off-the-shelf individual sensors of this part number. They even provide the measured curve-matched resistance/temp (R/T) table on their website. They are indeed very high precision thermies... so we may as well take advantage, ehh?
I'm thinking your 450 might learn us a lot... so I'd like to make a clamp-on copper sensor for the oil supply hose fitting and switch sensors using that 4th button to operate a latching relay.
This feature will be optional if I can pull it off though.... I ain't gonna insist on it. Its your call.
post #146 of 174 (permalink) Old 06-04-2019, 07:12 PM
wheelsquad's Avatar
Liked: 597 times
@retro, I forgot to tell you about one rule I have in life, once something gets to be over 3 buttons....it has to be replaced with a touchscreen. Time to start project over.
post #147 of 174 (permalink) Old 06-04-2019, 08:15 PM Thread Starter
Liked: 2933 times
Hahaha... a 1080P display...? Or shall we go all in with a 4K HD?
I got the display window cut out and the LED hole drilled without screwing up the enclosure today and the buttons & tinted window are sealed an' curing. This one looks fabulous so far!
I'll finish the harnesses and power supply/relay hookup wiring as soon as my next shipment of 18 gauge wire spools arrives. This gizmo is ready to calibrate and assemble now, so it should be completed about two days after that wire arrives. I'll dump pics as it progresses. :-)
I been thinking a bit more on that 2nd sensor idea... while it might be useful, I'm beginning to get cold feet. We'd need a two-color LED to indicate which sensor is active, a tactile switch would have to be fabbed in and wired up, extra electronics added to the relays box... and a lot more wire pulled from the spools.
Will all of that extra work and expense add enough practical value to our simple lil' gizmo, to justify those efforts? I doubt it really... it is doing everything we asked for already and then some... and it is doing those jobs very well. Lets keep it simple... lets call it a day and run it, me thinks. :-)
Besides, I only have one touchscreen left in stock. And it's the only backup that I have for my phone. :-)
post #148 of 174 (permalink) Old 06-06-2019, 03:38 AM
Liked: 6534 times
I wonder if Honda engineers read this forum , maybe they could learn a few things -----
Jeepwm69, _Wilson_, SamUK and 1 others like this.
post #149 of 174 (permalink) Old 06-06-2019, 09:45 AM Thread Starter
Liked: 2933 times
I kinda doubt it... don't you? Corporate engineering departments are inhibit-ively structured and compartmentalized to serve defined company roadmaps which are laid out over long terms. Objectives are already known, years in advance... and they all tend to primarily serve the financial health of the company. As a result much of the R&D budget goes into small (but expensive) exploratory projects that are centered around developing clever, complex integrations that more efficiently entrap/enslave the consumer... control of product lifetimes/lifecycles, both at the systems levels and the individual component levels are very important to them. Larger projects (a new motor for instance) are developed from those past & present explorations and experiences over terms spanning several years. So environmental pressures in large corporate engineering departments tend to be predatory in nature... focusing on reducing manufacturing costs and creating predictable revenue streams for the company and its support networks (distributors, dealers, etc.) after the sale. I can't see how enthusiast forums could be of any interest to the manufacturer. There is nothing here that is not already known and nothing here that they could take advantage of. Are there?
Assuming that I won't let the smoke out, I expect to calibrate this gizmo on the stovetop today and seal the enclosures up. Pic dump later on... :-)
fishfiles likes this.
post #150 of 174 (permalink) Old 06-06-2019, 10:14 AM Thread Starter
Liked: 2933 times
Thread derail alert...!!! I've been sleeping on a'nudder-nutter-in-the-woods DIY project for a few months now. I'm pretty confident that I've got the major design and components choices down pat and I'm getting anxious to get some aluminum chips flying. This idea came from you folks... I think it began with a suggestion from @SamUK and then later on more reinforcements came from @fishfiles. I feel like I have a good, strong design all figured out now... for a pair of portals to fit on the front ends of the older Hondas. I'm thinking about a 4 inch left/right set for the first build, assembled either with, or without a GR. They'd be relatively cheap to make and use common, already available parts if I can pull it off. Gotta talk to my buddy about using his Bridgeport vertical mill first though. :-)
fishfiles, _Wilson_ and SamUK like this.
does this fourtrax have oil cooling or fan cooling please read iijason Honda FourTrax 18 09-26-2017 06:02 PM
