A Creamsicle Orange - Page 36 - Honda ATV Forum
 548Likes
post #351 of 367 (permalink) Old 12-26-2018, 08:11 PM Thread Starter
Liked: 2767 times
Well, I'm not sure that I can pull that headlight swap off yet. I've never seen a Rancher 350 with a 3rd headlight, so my 1st idea might turn out to be pretty hokey looking. I've got the pieces in hand, just don't know whats gonna happen when I start fabbing it up. I think @fishfiles nailed it when he said the Creamsicle is going into morta'mor'fa'cis ! I'll show y'all what I have in mind in a few days.
Hints: Its a dirt cheap mod/idea. It features both high & low beams. Its a DOT legal headlight. And it is Orange. :-)
I've ordered enough of those OEM fenders clips to last me for a while. Here is the seller link:
https://www.ebay.com/itm/273517269198
fishfiles and Jeepwm69 like this.
post #352 of 367 (permalink) Old 12-27-2018, 02:56 AM
Liked: 6291 times
I have a few extra headlight pods with the mounting bracket from 450's I could throw your way , I could see it working to mount that pod onto a 350 , the hole where the dash display was would have to be closed in , which it could become a place to mount toggle switches or maybe a hinged cover and turn it into a storage compartment
Jeepwm69, _Wilson_ and retro like this.
fishfiles is online now
post #353 of 367 (permalink) Old 12-27-2018, 11:08 AM Thread Starter
Liked: 2767 times
If I had a plan B in mind that 450 light would probably be it! The Rancher display cover is a cheap plastic part, so I'm probably gonna hack on mine a bit to adapt. So if it ends up looking like a Rancher wearing a Halloween mask it will be easy to put it back stock. I'm still staring at it... lol
post #354 of 367 (permalink) Old 12-31-2018, 11:59 AM
Liked: 2936 times
Yeah that 450 meter looks about the same size as a 350.
Here's what I did on the wife's 09.
https://www.hondaatvforums.net/forum...t-rancher.html
retro likes this.
Jeepwm69 is online now
post #355 of 367 (permalink) Old 05-11-2019, 06:12 AM
Liked: 6291 times
I got redirected to this thread from Retro's link , some good reading , missed or forgot a lot of it
Jeep , I just seen someone took the headlight pod off his atv and put the dash into a no light pod , think it was Whiskers' on the Foreman site
retro likes this.
post #356 of 367 (permalink) Old 05-13-2019, 08:51 AM
Liked: 2936 times
Yeah I saw that. I need as much light as I can get. Blind as a bat. That headlight delete looks slick, but won't help me much at night.
post #357 of 367 (permalink) Old 05-16-2019, 08:32 PM Thread Starter
Liked: 2767 times
My 3rd headlight idea is on hold and has been for quite some time. My idea requires a lot of fabbing work and I don't have time to devote to that project, so its off the table. I'll try again some other time. I plan on swapping in 420 front disc brakes next winter, so maybe I'll get back into the headlight project during that next teardown/maintenance session. For now I'm gonna concentrate on getting this bike back together so I can put it to work in the woods cleaning up a bunch of dead/diseased spruce trees on my property. The following mini-sagas are what I got goin' on... :-)
A while back I made a new, updated selectable gizmo for it, but its been sitting inside a plastic bag in a box awaiting time to install it. Today I got it bolted in place finally, using the same mounting holes that I had the 1st version bolted into. I hope to get all of my new updated, waterproof wiring connectors soldered up to the sub-harnesses tomorrow, along with all of the other electrical addons/changes I got goin' on. I took apart all of the old wiring addons today, so I'm gettin' ready to rock... :-)
Lets get rollin' with a pics dump!
ID:	136516   Click image for larger version
ID:	136518   Click image for larger version
ID:	136520   Click image for larger version
Jeepwm69 and _Wilson_ like this.
post #358 of 367 (permalink) Old 05-16-2019, 09:20 PM Thread Starter
Liked: 2767 times
Being as this is also an electric-tronical-gizmo and it requires one wire to be soldered up... I also mounted up the new cooling fan gizmo today.
As mentioned in the DIY build thread for this gizmo the power supply/relays box was mounted on the underside of the modded KFI winch plate in drilled & tapped holes using #10-32 buttonheads. Then the winch plate & winch assembly was bolted back in place on the frame and the new harnesses routed & zip-tied along with the pre-existing subs.
Lets pause for a few pics o' that... :-)
ID:	136524   Click image for larger version
ID:	136526   Click image for larger version
post #359 of 367 (permalink) Old 05-16-2019, 09:28 PM Thread Starter
Liked: 2767 times
Topside in the office, the gizmo control unit mounted down on the left-side handlebar directly above where the waterproof winch rocker switch was mounted below the bar. The aluminum bracket that I made for this control unit was shaped just right when I cut it out of a length of extruded something or other... so that I could just remove the two screws holding the rocker switch housing to the handle bar bracket, sandwich the new bracket between the rocker & bracket, line up the two bracket holes and put those two screws right back in. This mount up was like takin' candy from a baby, it just doesn't ever get any easier than this out here in the boonies! :-)
We like pic dumps the most tho, don't we..?
ID:	136530   Click image for larger version
ID:	136532   Click image for larger version
_Wilson_ and GirlsRideToo like this.
post #360 of 367 (permalink) Old 05-16-2019, 10:01 PM Thread Starter
Liked: 2767 times
Meanwhile, another lil' electric related relocation is in the works to be soldered up tomorrow so I took a pic of that newfound treasure. I wanna thank Trailfreak for finding & sharing this lil' hideout! I doubt if I would have ever noticed that free space area in the frame in front of the fuel tank if it weren't for him pointing it out to us! And its a perfect space to relocate my waterproofed winch contactor into!
Last summer I had made a bracket that hung that contactor from the frame because I did not want to drill any holes in the trunk and mount it inside there. But I worried about that choice...
I keep the OEM tool kit in the trunk, a good low-pressure tire gauge is velcro'd to the wall, the OEM user manual is in a ziplock in its overhead compartment, a lot of small tools & misc. stuff I use in the woods are inside that dry-box, along with a 30' heavy tow rope, clean leather gloves, first-aid kit, toilet paper sealed in a ziplock... etc. That box stays clean and dry inside and its jam-packed useful... so I just couldn't bring myself to drill any holes in it... so I had mounted the contactor out on the frame where it took mud and water hits after taking it apart and sealing it up tight with Ultra-black.
I'm relieved that I won't have to worry about that contactor taking a hit, ever again. Thanks Trailfreak!
