A Creamsicle Orange - Page 3 - Honda ATV Forum
 551Likes
post #21 of 367 (permalink) Old 02-20-2018, 06:23 AM
XplicitRacing6's Avatar
Liked: 520 times
I hope she likes it!! Thats awesome your mom will even get on a sled and quad. My mom wants nothing to do with them. I look forward to watching this thread. Retro you make your bikes cleaner than when they left the showroom floor.
SamUK and retro like this.
  • 2001 Honda TRX 416ex
  • 2003 Honda TRX 416ex
  • 1999 Honda 300ex
  • 2014 Polaris 1000 xp Turbo
  • 1998 Yamaha PW 80
XplicitRacing6 is offline
post #22 of 367 (permalink) Old 02-20-2018, 12:40 PM Thread Starter
Liked: 2776 times
Well, she is 78, but I noticed that she has slowed down a lot now that she lives nearby... she still does everything she wants to, just slower. Still wants to be independent and do all the things she enjoys doing outdoors without asking for help though. She will use her ATV a lot this summer me thinks, even for trail riding through the woods for fun, and for showing her visiting grandkids all the cool places she has explored.
I won't be doing a frame up resto on this one though. Just intend to tear it down far enough to get eyeballs on most of the major moving parts and clean and repack all the bearings, replace seals and bushings and any worn out/broken/missing parts that I find along the way. I don't care whether it is ever shiny or not. I just don't like to fix problems one at a time on machines in the order as they might occur.... that approach can cause me to become stranded somewhere and chasing occasional gremlins wastes a lot of my time.
I prefer doing complete teardowns to service everything at once to head off any potential breakdowns or failures that might be avoidable. I feel like I am saving a lot money and time on repairs and maintenance when I can clean and repack an old bearing that might last for many more years, if only it had plenty of good clean grease in it. In my view, it is just an act of taking routine preventive maintenance chores one step further.
I own and depend daily on a LOT of very old equipment. All of my durable and reliable old-school machines were torn down and serviced as soon as I got them, before ever being put to work. I do the same teardown procedures on every brand new machine I buy too! New machines need them the most! I simply repeat those routine teardown sessions on each one every several years. My repair hours and costs each year usually total very near to 0 hours and $0.00. I spend my time and money on thorough, scheduled (at my convenience) maintenance sessions instead...
Which means I worry less about anything breaking down when I need it the most. And I rarely have to scrounge for and spend a fortune on any obsolete parts. I NEVER buy any china stuff when it is an avoidable consequence. Being that I am a hardcore tightwad and a practicing cheapskate, this attitude and approach works the best for me.
post #23 of 367 (permalink) Old 02-21-2018, 10:56 PM Thread Starter
Liked: 2776 times
It finally stopped snowing early this morning, so this afternoon I spent some time looking the Rancher over out under a bright sun for the first time. It is still pretty grungy looking on the tops of the plastic surfaces I noticed right away. I'm sure everything will wash clean and bright with some hot soapy water and a scrub brush though. One piece at a time...
I noticed in one of those roadside pics that I took the day I bought this, that a front rack bracket was bent where the left side top of the fender mounts through a rubber grommet. So first thing today I checked that out and noticed the front bumper and rack are bent (you'll see what I mean in the pics I'll soon post) in a little. Luckily the plastic fender wasn't found cracked or damaged around that grommet. The bumper and rack are made of light tubing so they should be easy to straighten back where they belong. No kinks or dents in either one, so no worries. I hadn't noticed any of that while I was checking the bike over in the man's garage.
I also noticed that several black plastic push pins are missing that hold plastics together in a few areas. I'll buy a package of 100 to replace them and keep the rest for spares.
One bolt (of two) is missing that holds the right foot peg down. One black plastic wheel cap is missing as well.
In the trunk I found the Owners Manual inside its compartment along with a new NGK spark plug. But the toolkit and the gear shift wrench are missing. Those were added to the parts list to be replaced as well.
It looks like a mouse began to build a nest inside the airbox, but must have abandoned it right away. The air filter inside was still clean and oiled, so maybe the little critter found a more pleasant living room in someone else' vehicle nearby. No harm done there... and no wiring or hoses were found chewed on the bike. Everything else on the bike checks out fine so far.
Next up, I opened the drain on the float bowl and let that empty out. It was still liquid, but a green and smelly liquid... So I unhooked the hose coming from the tank and slipped a short length of hose over the inlet nipple and stuck a small funnel in it. I poured some of my premium 32:1 chain saw premix into the funnel to fill the bowl, then opened the drain again to flush it out a bit. I closed it back up and filled the float bowl with premix again. I put a battery in it, then yanked the air filter and squirted a bit of premix into the carb... turned the key on and tested the shift buttons... R-N-1-N... Sweet!!!
So I pulled the choke and pushed the button and it fired right up! I let it idle for about 20 seconds (the hour meter rolled over to 500.0 hours as it was idling) then shut it down. It sounded pretty darn good to me, so now I can continue the rehab without worry or wonder about a gazillion "what ifs". :-)
The reason I was not 100% confident with the motor until now, is because the hose on my old-school made-in-the-USA compression tester cracked open while I was trying to screw it into the 12mm adapter (already threaded into the head) in the man's garage. The angle I had to bend it around as I twisted on the hose was severe and in the cold air temp the hose cracked open. I had tried to hold the crack shut with one hand while the other hand pressed the starter button, but I couldn't make the hose airtight. The building pressure would blow off through the cracked hose. 55 lbs is as high as I saw the gauge go on a hit, so I used other simple clues (no evidence of oil or soot in the exhaust, it wiped clean and dry. The spark plug came out tan color too, no soot, carbon or shiny oil deposits on it) to form my opinion. The Odometer read 4,723 miles. The hourmeter read 499.9 total hours. I also had the man's word that it was all good. Now I am 100% confident that his word is good too! :-)
Creamsicle is a gift me thinks!!! :-)
Due up next: Pre-teardown PIC PORN. I am about 20% into the teardown right now, so this is the only pic dump you'll see of the "Before" condition of Creamsicle. I added a shot of the color code (YR-222R) sticker too. Honda calls it "Zest Orange" in parts fiche listings.
ID:	112265   Click image for larger version
post #24 of 367 (permalink) Old 02-21-2018, 11:03 PM Thread Starter
Liked: 2776 times
Pre-teardown pics #1
ID:	112281   Click image for larger version
ID:	112289   Click image for larger version
ID:	112297   Click image for larger version
ID:	112305   Click image for larger version
post #25 of 367 (permalink) Old 02-21-2018, 11:07 PM Thread Starter
Liked: 2776 times
Pre-teardown pics #2
ID:	112321   Click image for larger version
ID:	112329   Click image for larger version
ID:	112337   Click image for larger version
ID:	112345   Click image for larger version
post #26 of 367 (permalink) Old 02-21-2018, 11:10 PM Thread Starter
Liked: 2776 times
Pre-teardown pics # 3
ID:	112361   Click image for larger version
ID:	112369   Click image for larger version
ID:	112377   Click image for larger version
ID:	112385   Click image for larger version
Goober, _Wilson_ and redtherocket like this.
post #27 of 367 (permalink) Old 02-22-2018, 02:14 AM
Liked: 6319 times
It is super clean , looks like it never went in the mud
Goober, XplicitRacing6 and retro like this.
fishfiles is online now
post #28 of 367 (permalink) Old 02-22-2018, 03:06 AM
Liked: 6319 times
You got a good deal , this cant-a-loupe Rancher popped up today on the local Craig's List for $1,100 and it looks rough
https://neworleans.craigslist.org/sn...501927160.html
Name:	cant-a-loupe Rancher .jpg
post #29 of 367 (permalink) Old 02-22-2018, 08:42 PM
Trailfreak's Avatar
Liked: 88 times
Nice Rancher! I like that color, donít see it that often. Around here they go for $2,000-$2,500. Some ask over $3,000 for them with a plow.
Iím interested to see what you get for compression. My 2001 ES compression was at 87 one time then 77 another time with 600 hours.
retro likes this.
Trailfreak is offline
post #30 of 367 (permalink) Old 02-22-2018, 10:00 PM
Trailfreak's Avatar
Liked: 88 times
Retro, BTW: welcome to the ES Club. We are told that our ESís are no good, are nothing but problems, always break, never buy one of those, not as good as the others. We are told to get rid of some of our parts to be like the others, they remind us to keep our batteries charged, like we donít know that!
We know ESís are not perfect, but and at the end of the day they work well, are reliable and are enjoyable to drive. What else could anyone want?
Welcome to our great happy club! We could use someone like you to be our club Vice President.
Goober and retro like this.
