elka shock adjustment - Honda ATV Forum
post #1 of 14 (permalink) Old 02-20-2013, 01:28 PM Thread Starter
brent's Avatar
hi guys i have a honda 250r atv i just bought but it has elka shocks on it and i no not know how to ajust them i have a camber problem on one tire and want to make sure my shocks are all adjusted right if anyone could tell me how to adjust them or where i can get instructions on how to do it i would appreceate that these are the best pics i have of them if u need better ones let me know thank you
ID:	12203   Click image for larger version
ID:	12204   Click image for larger version
ID:	12205   Click image for larger version
brent is offline
post #2 of 14 (permalink) Old 02-20-2013, 09:04 PM
atvrider13's Avatar
Liked: 33 times
Here is a downloadable manual from elka : Owner?s Manuals | Elka Suspension
Your shocks have a knob on the reservour that adjusts the compression, turning it in increases compression, out less. Your shocks dont have rebound adjustment. They do have a threaded body for adjusting preload for ride height and body roll / softness or hardness. You just loosen up the allen locknuts and turn. As for your camber problem, i dont think your a-arms are adjustable. You may need a new one.
atvrider13 is offline
post #3 of 14 (permalink) Old 02-21-2013, 03:09 AM
american opel's Avatar
Liked: 5 times
^^^^^agree.setting the preload doesn't change caster-camber.when compressed the only thing that changes is toe.{that's what couses arm pump}.your shocks should be set up for your ride weight and arms.alot of times people just buy shocks thinking they will work but if they arn.t set up right the stock ones work better.
american opel is offline
post #4 of 14 (permalink) Old 02-21-2013, 04:58 AM
Redracer's Avatar
Liked: 5 times
WHAT??? How does that cause arm pump? Are pump is forearm fatigue caused from the strain of riding for an extended period of time. Muscle tension restricting the flow of blood in the muscles through your forearm and hands.
Dynamic Graphics, Inc.
Aurora Honda
LoneStar Racing
Leatt
Fox Shox
HondaATVForums.NET
Redracer is offline
post #5 of 14 (permalink) Old 02-21-2013, 05:09 AM
Redracer's Avatar
Liked: 5 times
If your shocks have rebound adjustment(doens't look like they do) there is a small flat head screw at the bottom of the shock below the spring and above the mounting point. Rebound adjust how fast the shock returns to it's normal position after being compressed. There are 2 types of compression, high speed and low speed. (need more pics to see what you have) High speed adjustment is for when you take a big hit, land flat off a jump, hit a square edge, blast through a G out, ect.. The Low speed controls the compression from body roll and the subtle bumps and hits that your quad takes. Like landing a jump pefect on the downhill side in the sweet spot, that is low speed.
High and low speed compression have nothing to do with your speed, it is the speed at which the shock shaft travels.
Aurora Honda
LoneStar Racing
Leatt
Fox Shox
HondaATVForums.NET
Redracer is offline
post #6 of 14 (permalink) Old 02-21-2013, 05:12 AM
Liked: 5 times
if the shocks arn't set up right or are the wrong lenght when going over bumps the quad will toe in and out,which will take the bars and try to shake them out of your hands!!the only way to keep it straight is to hold on tight and keep compinsating because the toe keeps changing and trying to make the quad steer different ways.
post #7 of 14 (permalink) Old 02-21-2013, 05:29 AM
rich250rracer's Avatar
Liked: 14 times
Changing preload will most definitely change camber, it will change ride height, which will change what position the spindle is in while it's sitting. Don't believe me? Put your quad on a stand, and take a shock off. Move the wheel through the travel and watch how the camber changes, along with the tow. Caster will not change. Think of a rail buggy and how the wheels are tilted at the top in while in a sitting position. As the wheels move through the travel, they become more upright.
2014 CRA Senior II and Buckeye Series champ
2012 CRA Senior II champ
2011 CRA Senior II and Buckeye series Harescramble Champion
2009 CRA Senior II and Buckeye series champ.
2007 CRA Senior II, and Buckeye series Harescramble Champ.
2007 TRX450R
2005 TRX450R
2004 TRX450R
2003 Lonestar 250R
1999 CR500
1999 CR250
1996 CR250
1986 ATC250R
1975 MR50
1999 Banshee
rich250rracer is offline
post #8 of 14 (permalink) Old 02-21-2013, 05:40 AM
Redracer's Avatar
Liked: 5 times
Perfectly said, thanks Rich
Aurora Honda
LoneStar Racing
Leatt
Fox Shox
HondaATVForums.NET
Redracer is offline
post #9 of 14 (permalink) Old 02-21-2013, 05:53 AM
Liked: 5 times
here is my son's and my R set at 1 1/2 ride height from the frame to the ground.the other is 12'' frame height.yes camber will change alittle but not very much!!
Name:	honda shocks 006.jpg
ID:	12215   Click image for larger version
Name:	honda shocks 007.jpg
ID:	12216   Click image for larger version
Name:	honda shocks 001.jpg
post #10 of 14 (permalink) Old 02-21-2013, 02:36 PM
Liked: 14 times
The a-arms aren't even full extended in the third pic, let those arms drop completely and look at the camber difference.
2007 TRX450R
2005 TRX450R
2004 TRX450R
2003 Lonestar 250R
1999 CR500
1999 CR250
1996 CR250
1986 ATC250R
1975 MR50
1999 Banshee
