1999 300 Fourtrax rear brake issue - Honda ATV Forum
 2Likes
post #1 of 11 (permalink) Old 06-22-2019, 12:13 PM Thread Starter
4TrAxmudd's Avatar
I canít get the rear brakes bled. I have pumped and held the peddle many times according to the service manual.Is there a rebuild kit for the master cylinder? Or is the caliper shot? The plunger in the caliper will not move.
4TrAxmudd is offline
post #2 of 11 (permalink) Old 06-22-2019, 12:53 PM
GirlsRideToo's Avatar
Liked: 445 times
Originally Posted by 4TrAxmudd View Post
I can’t get the rear brakes bled. I have pumped and held the peddle many times according to the service manual.Is there a rebuild kit for the master cylinder? Or is the caliper shot? The plunger in the caliper will not move.
There is a sub-assembly for the master cylinder at partzilla:
https://www.partzilla.com/catalog/ho...aster-cylinder
Rockymountainatv.com probably has one, too.
Can you get brake fluid to flow through the master cylinder and to bleeder valve?
If the slide pin is seized you most likely will not be able to get it to turn. Is it really seized or is the head stripped??
I hope others can give you more advice about this problem.
If it were me, I'd replace the caliper first before rebuilding the master cylinder. Inspect and clean the master cylinder and hose.
Hope this helps you.
GirlsRideToo is offline
post #3 of 11 (permalink) Old 06-22-2019, 03:51 PM
_Wilson_'s Avatar
Liked: 1801 times
Question Question
Has this 300 been moded with rear hydraulic brakes ? Or, are you talking front brakes ? Because the trx fourtrax 300 has rear cable brake operated, however.... they should have factory with hydro disk....just my 2 ...
_Wilson_ is online now
post #4 of 11 (permalink) Old 06-22-2019, 05:13 PM Thread Starter
4TrAxmudd's Avatar
It has the hydraulic disk on it.
post #5 of 11 (permalink) Old 06-22-2019, 08:27 PM
Liked: 3145 times
Here is a sticky with info that you can apply to your disc brake system:
https://www.hondaatvforums.net/forum...ur-brakes.html
_Wilson_ likes this.
post #6 of 11 (permalink) Old 06-23-2019, 04:00 AM
_Wilson_'s Avatar
Liked: 1801 times
https://www.hondaatvforums.net/forum...y-charged.html
I see by your other post (battery charge issue) this is a 300 ex .
fishfiles likes this.
post #7 of 11 (permalink) Old 06-23-2019, 04:08 AM
Liked: 6750 times
Keen eye ! I was wondering about disc on the rear of a 300 Fourtrax
fishfiles is online now
post #8 of 11 (permalink) Old 06-23-2019, 04:23 AM
_Wilson_'s Avatar
Liked: 1801 times
Thx! Had me wondering to. However, I was looking forward to a TRX 300 rear disk build.
post #9 of 11 (permalink) Old 06-23-2019, 05:46 AM Thread Starter
4TrAxmudd's Avatar
Yes it is.
post #10 of 11 (permalink) Old 06-23-2019, 09:39 AM
Liked: 4278 times
this is why it clearly says on every thread section...PLEASE POST THE FULL MAKE/MODEL/YEAR !. notice the make in these words ??. BIG DIFFENCE BETWEEN A TRX300, AND TRX300EX !.
