I'm mystified...brake lever very tight...again!!! - Page 2 - Honda ATV Forum
 16Likes
post #11 of 27 (permalink) Old 06-11-2019, 08:39 PM Thread Starter
Budweiser's Avatar
Liked: 48 times
Originally Posted by LedFTed View Post
i had a truck, think it was 76 ford, henry. any way, when i hit the brakes, the fluid would go forward, but not return. it made for awkward breaking, and turning. i had to replace the front break lines on both side's. problem solved. i doubt hondaatv has this problem, but it can happen.
maybe i'm the only one this happened to, hard to believe, though it could be so.. stranger thing's have happened. i have seen a few.
I was able to blow air threw them so I don't think the lines are plugged. And that's not pressurized air, just air out of the nozzle. I'm thinking there must be some sort of return in the MC. Maybe its plugged. The force of my hand pulling the lever is enough to get the brake fluid to move to work the wheel cylinders but the MC is not allowing the brake fluid to flow back into the resivour when the brake is released. Which keeps the wheel cylinders pushed out and the brake lever tight. At least this is what I'm thinking the problem is! I could be way off.
Budweiser is offline
post #12 of 27 (permalink) Old 06-12-2019, 07:15 AM
Liked: 1337 times
Did you replace the MC seals?
When I replaced my seals the first time i put one in backward—they are directional. I slso had to scrape off a waxy looking build up on the piston. I also had to unplug the two orifice in bottom of the mc.
If you didn’t get into the mc last time then yes, I would get into it.
Goober is online now
post #13 of 27 (permalink) Old 06-12-2019, 11:56 AM Thread Starter
Budweiser's Avatar
Liked: 48 times
When I replaced my seals the first time i put one in backward–they are directional. I slso had to scrape off a waxy looking build up on the piston. I also had to unplug the two orifice in bottom of the mc.
AHHHHHHAAAAA!!!! So there are 2 orifice in the bottom? Maybe 1 is for outgoing brake fluid and 1 is for return? That makes sense to me and is good to know. Thanks!
I haven't touched the MC. I ordered the rebuild kit and it should be here soon.
misterclean59 likes this.
post #14 of 27 (permalink) Old 06-13-2019, 07:55 PM
LedFTed's Avatar
Liked: 446 times
Henry, was an older truck, so it probably dont apply. i might have been able to blow air both way's through the brake lines or not. fluid though, only one way. i never seen this before, never seen it since. i just happened to be the lucky one, this happened to.. strange thing's happen. it's just a given.
i clicked in on the KY Derby once.
2000 450es TRX
2 grass hog 4x4s
sum humor adds up
LedFTed is offline
post #15 of 27 (permalink) Old 06-20-2019, 08:14 PM Thread Starter
Budweiser's Avatar
Liked: 48 times
So I got the rebuild kit. After I got it apart, I see the 2 orifaces. 1 is very very small. Is that correct? As is so small a I used a piece of wire from a wire brush to unplug it. Sound right?
Everything went back together as it should but now the brakes don't seem to be bleeding. The entire system was emptied of brake fluid so I'm sure it will take a bit to get brake fluid down to the bleeders but the brake fluid in the MC doesn't seem to emptying like I would expect.
Is the metal plunger supposed to go in a certain way? I just slide it in. I think its also leaking brake fluid from the plunger seal. Did not do that before.
Now I'm frustrated! Not much to screw up!
20 minutes later....I clamped the rubber brake line with vise grips. I can hear brake fluid coming out the plunger and its leaking. So I'll have to take it apart tomorrow to see what I did wrong!
post #16 of 27 (permalink) Old 06-20-2019, 08:37 PM
Liked: 2976 times
Was there a piston in the kit already assembled with a new cup seal on it? If so just slide it in... but note that the cup seal lip must face towards the bottom of the bore so it holds fluid pressure while applied, but can collapse to allow fluid to flow back past the seal when the piston is withdrawn by the return spring. The cup seal shape makes the master cylinder into a positive displacement pump only while the piston is being pushed into the bore, in other words.
If you have the master cylinder assembled correctly but it leaks, the bore might be pitted or burred, or its possible the new kit parts do not fit that master cylinder.
post #17 of 27 (permalink) Old 06-20-2019, 08:51 PM Thread Starter
Budweiser's Avatar
Liked: 48 times
The kit was a Honda rebuild kit. The cup seal was not on the piston, I had to slide it on. Don't think I did it wrong, I copied the original. But I may have!
I'll take it apart tomorrow.
retro likes this.
post #18 of 27 (permalink) Old 06-20-2019, 10:02 PM
LedFTed's Avatar
Liked: 446 times
i might be wrong, but clamping brake line's, just dont seem right. ya might have to have help with bleeding, the brakes. i have..
no matter, atv's or truck's. {i left out cars, farm tractors, anything with a hydrolic brake line}, it just is...
manual brake lines, should ya run across them, a different matter. like emergency, brakes.
2000 450es TRX
2 grass hog 4x4s
sum humor adds up
LedFTed is offline
post #19 of 27 (permalink) Old 06-21-2019, 01:06 AM
Liked: 4258 times
my money was on the small hole in the bottom of the master cylinder. this is your return line. if your brakes are sticking like you said ^^^ ?, this tells me your return line hole in the master cylinder is clogged.
post #20 of 27 (permalink) Old 06-21-2019, 01:07 AM
Liked: 4258 times
and your wrong..lol. been doing it this way for over 20 years, not once have I had any issues bleeding brakes on atvs.
_Wilson_ and LedFTed like this.
