Front brakes still don’t work until pulled all the way - Page 2 - Honda ATV Forum
 6Likes
post #11 of 15 (permalink) Old 05-15-2019, 03:50 PM
Liked: 1341 times
I try to splain it to you 3x now lol
“Use a flat screwdriver to gently take out that flat rubber puck—that’s where the air gets trapped.”
Yup the outside is hard rubber the inside is very delicate—pry from the outside rim
Goober is online now
post #12 of 15 (permalink) Old 05-15-2019, 03:55 PM
Liked: 4259 times
Originally Posted by 86Hondatrx350 View Post
How exactly should I remove it, can’t really see see what you’d pry on it where to grab on to it with pliers?
just pry it up and out, it just rest down in there. a mech pick, pocket knife, anything that you can wedge in between the rubber part, then just pry it up and out, nothing to it 🙂.
I’m looking at it and don’t know what to pull off, there’s an outside rubber layer, then a harder inside layer then on the lowest point there’s a rubber ring then the plunger with slits in it at the very bottom. What should I pry up?
pry the round part up, its like a quarter in size.
post #13 of 15 (permalink) Old 05-15-2019, 04:17 PM Thread Starter
86Hondatrx350's Avatar
Liked: 9 times
Originally Posted by Jeepwm69 View Post
I wouldn't worry about messing it up. If you think it's the master cylinder you can get a new aftermarket one cheap or buy a used OEM Honda one for just about any ATV and it will bolt right in.
Sorry, thought it would be more complicated than it was. I did what you said and I popped out like nothing, wiggled the lever a bit and no bubbles came out. I the puck back in and it had no effect... at least I know what to do next time.
I’ll ride it around for a bit and see it the brakes stay or stop working.
Thanks for all the help
Goober likes this.
86Hondatrx350 is offline
post #14 of 15 (permalink) Old 05-15-2019, 06:19 PM Thread Starter
Liked: 9 times
Zip tying the lever won’t do anything except maybe prove the piston seal is worn.
If your lever won’t hold, buy a master cylinder rebuild kit ($20).
Remove the lever
Gently remove that piston dust cover–i used needle nose but try not to tear it. The new kit comes with a new cover.
Use snap ring pliers to remove the snap ring from the housing–you’ll probably curse blue smoke trying this. Then remove the piston.
The piston seal goes in one way–take careful note Of the position.
I've actually had good luck zip tying the lever back IF you are having trouble bleeding air out of the system. It won't help for anything else, and sometimes it doesn't even get all the air out of the system, but it's a cheap and easy "leave it till tomorrow" trick to try if you're having trouble bleeding the system. I've done it a couple of times and come back to a wheeler with a nice firm brake lever.
Well, I drove it around for an hour and the brakes seem to work flawlessly now!
Appreciate the help!
Now to find out what the whirling from the front left is...
Goober and _Wilson_ like this.
post #15 of 15 (permalink) Old 05-16-2019, 03:39 AM
LedFTed's Avatar
Liked: 446 times
Remove the lever
i was cursing black smoke, with my snap ring pliers, on the 2000. there was a lot of sludge in the piston area, all 3 time's, i was cursing black smoke, getting that c-ring out. i had to clean it more than once.
2000 450es TRX
2 grass hog 4x4s
sum humor adds up
LedFTed is offline
Front Brakes Only Work when I pump them joejoef420 Brakes & Suspension 12 02-20-2019 04:13 AM
1989 Honda Fourtrax 300 Carb Settings & Tire Issues. Thwapp Honda FourTrax 24 09-25-2017 05:45 PM
TRX300FW '95 - Front ticking noise (Pics) machinecrook Honda FourTrax 28 04-16-2017 11:21 AM
Brakes questions Demonhunter Honda FourTrax 3 11-10-2016 02:31 AM
Rancher 350 Front Brakes Ranchero Repair & Maintenance 19 06-13-2016 08:29 AM
