1999 Honda trax 300 4x2 disc brake conversion - Honda ATV Forum
post #1 of 11 (permalink) Old 06-21-2018, 12:12 PM Thread Starter
Dropzone's Avatar
I just purchased front disc brake conversion for my 1999 Honda trax 300 4x2 from SUPERATV. The discreption shows that it fits my atv. However, it seems that I need hubs to make this work. Problem SUPERSTV can't tell me where to find them or what hubs will work. Can someone help me with this problem?
Dropzone is offline
post #2 of 11 (permalink) Old 06-21-2018, 12:52 PM
LBZ_Duramax's Avatar
Liked: 209 times
SATV doesn't sell a kit for a 2wd trx300. Only the 4x4 that's why you don't have the hubs.
2016 Honda Pioneer 1000-5 Deluxe White
30" Outback Max on 14" C-Series Beadlocks
Superatv Forward Arms
2008 Honda Rancher 420 4x4
Money Pit......soon to be greatness
1998 Honda Trx300 4x4
317 motor, 54% Gear Reduction, EBC Clutches, Big Red Rear End, 2.75" Stretch, 350D Clutch Cover, Oil Cooler, Foreman 450 Clutch, Disc Brake Kit, 29.5 OG Laws
1985 Honda Big Red 250 ATC
18% Reduction, 28" EDL
Sold
19 - Honda Trx300 4x4
LBZ_Duramax is offline
post #3 of 11 (permalink) Old 06-21-2018, 12:55 PM
Liked: 6532 times
I would send that kit back to SuperATV , and get credit on it , they only sell 4x4 300 kits now days , the kit you need is discontinued from them , maybe you can find a hub that will work for you I don't know , I would think by now if there was a hub out there some one would have found it , if I were to start looking for a hub , I would look at a 350 Rancher 2x4 hub as that is the kit I used to put disc on a 300 2wd , here is a link to a kit that would work for you , you would still need shims and to make a 2 new brackets for the caliper mounts , the price went up another $49 since I last looked at it a month or more back , I was very lucky to have bought kits from Super ATV at $200 a few years back
https://www.ebay.com/itm/HONDA-RANCH...nd!70471!US!-1
fishfiles is offline
post #4 of 11 (permalink) Old 06-21-2018, 01:11 PM
Liked: 6532 times
In the pic , the gold mount is for the Rancher 350 2x4 , it has a offset at the end , you need to make a plate exactly the same except flat , 5/16 plate would be perfect and not need any shims , 1/4 plate will work with some shims from McMaster Carr is where I got them from
ID:	126748   Click image for larger version
ID:	126750   Click image for larger version
post #5 of 11 (permalink) Old 06-21-2018, 01:22 PM
Liked: 6532 times
When I said exactly the same , I meant the center of the spindle to center of holes for bolts that bolt the caliper to the mount --------------- but you do have to make the mounting circle to the spindle to fit the 300 2wd and re-index it
for the 1st gen 300 2wd's , if you noticed how much smaller the pattern is for the 2wd black plate ( 2nd gen ) compared to the 4wd gold plate , there is a big difference , the 1st gen 300 2wd is even smaller a pattern and there is barely enough to get the bolts head covered
post #6 of 11 (permalink) Old 06-21-2018, 03:25 PM Thread Starter
Dropzone's Avatar
Is the wheel bolt pattern for the kit a 4x110?
Dropzone is offline
post #7 of 11 (permalink) Old 06-21-2018, 03:38 PM
Liked: 6532 times
Yes , 4-110 and you need to have 12 inch rims to clear the calipers , aluminum rims are OK even though some kits say they are not OK
post #8 of 11 (permalink) Old 06-21-2018, 03:39 PM
Liked: 6532 times
I have seen people take the brake drum and cut it to resemble a hub and go from there
post #9 of 11 (permalink) Old 06-21-2018, 04:28 PM Thread Starter
Dropzone's Avatar
The 5/16 plate is thick enough for the re-indexing for the bolts? And making this plate is the only alteration that needs to be done to make this conversion work?
Dropzone is offline
post #10 of 11 (permalink) Old 06-21-2018, 05:07 PM
Liked: 6532 times
if you were to buy the kit I hyperlinked and use 5/16 plate you should be good to go , 5/16 plate is theoretical as I have never used 5/16 plate , I used 1/4 inch plate and 1/16 of shims to make the rotor ride right in the middle of the brake pads , 1/4 and 1/16 is 5/16 ---
