honda 300 fourtrax - Page 2 - Honda ATV Forum
post #11 of 15 (permalink) Old 02-08-2011, 01:21 PM
livingston lakeside's Avatar
A little update
Got the bed on and added rear springs - you can see them peaking out just below the muffler
Name:	Lakeside Trax Truck 2 8 11.jpg
livingston lakeside is offline
post #12 of 15 (permalink) Old 02-08-2011, 02:07 PM
Liked: 27 times
Looks like that might turn out pretty good.
post #13 of 15 (permalink) Old 02-08-2011, 05:43 PM
blowfishRus6's Avatar
for the buggy, with the weight on the rear end of the bed (when loaded) a full axle tube that spreads the weight out over the rear, instead of just at the bearings at the diff i think it would really benifit you.
jemmy3 did a GREAT write up on the install. not a hard swap, just hope you have a good rear from the get go!!!!!! pretty sure that is what my problem was.
88' 300 fourtrax 2wd
blowfishRus6 is offline
post #14 of 15 (permalink) Old 02-08-2011, 05:46 PM
like helmut said, once you modify the the bolt up location to the 300 swing arm, its a direct bolt on and go rear.
post #15 of 15 (permalink) Old 07-29-2013, 08:34 PM
Liked: 6750 times
250 Fourtrax or TRX350D
I put a 1986 TRX250 Fourtrax rear in my 1996 Honda TRX300 and it was very easy , I had and extra swing arm which made lining everything up and welding it a snap , I was able to do it all on a table , to make a bolt on flange which I welded to the tube I took a center section of a 300 rearend which I had and cut it about 3 inches long , then cut it in half , this sandwiched the axle tube but had a little gap , I took another piece of pipe and cut it like 4 inches and then cut it in half and took about 1/2 inch off the lenght of each piece , slide this pieces under the flange and used a c clamp and squeeze it all together off set the slices and welded down the gap of the pieces , welded it all the way around and unbolted it from the mock up swingarm and put it on the ATV , used a band saw to cut the steel bushing on the lower end of the rear shock flush with the eyelet as it stuck out the rubber about 3/8 on each side , I wanted to use the 250's 25x12x9 tires and rims and the right side hits the muffler on a hard bounce , 1 inch wheel spacers took care of that , there was nothing else to do and I really think the 250 rear end is heavier duty , never done the 350 swop , but read about it and I think there are shock mounts to deal with as it had 2 ---- oh , one other thing was I didn't use the trailer ball hitch plate as the angle was too much on the 300 and thats another project I need to do ------------ need to figure out how to do pics as the 250 axle job looks good
fishfiles is offline
