3003 Honda Rancher 350 - Honda ATV Forum
post #1 of 5 (permalink) Old 05-19-2015, 02:39 PM Thread Starter
mbod17's Avatar
I'm thinking about upgrading from my 2002 Honda recon 250 to a 2003 Honda rancher 350 $X$(trx350fm). I really want 4 wheel drive and found this one for $1895. Think it's worth it? Anything I should look for? Also, do these machines have a great reputation like the recon does?
2002 honda recon es
mbod17 is offline
post #2 of 5 (permalink) Old 05-19-2015, 02:54 PM
mrbb's Avatar
Liked: 1990 times
well as far as I know all the honda's with tubed rear axles like this has, the left wheel bearinga dn seals werew all weak links, the seal goes, allowing water in and that ends up killing the splines on the rear axle\ its a easy deal to replace and go new, like 25 bucks, and easy ti install as well
way cheaper than a 200 buck axle, thats for sure, as I found this out the hard way, I now keep close eye on mine LOL
other wise its all the basic's of checking over a used atv, all wheel bearings are prone to wear, and at this age, there something I would look at
next would be oil, is it CLEAN new looking or?? if dark it says NO recent oil change was done, which to me when looking at a used atv is a good thing, as older oil will show signs of water in it if its been run in deep water
same would be for diff.'s, but harder to inspect. when most sellers go to sell, they tend to replace these things to cover up any issue's at times??
I recommend re changing when you get it , so you know its done right!
next will be look for obvious signs of crash damage, bent parts, racks, handle bars levers, fresh paint to cover things up
inspect the air filter, a good owner keeps it clean and oiled, a some what lazy on PM's owner, it will be rather dirty and dry IMO!
do hours and miles seem right to you?? are wheel bent up at all, that tends to show an aggressive rider been running it!
its looks like a clean atv in the pic's but its always hard to tell real conditions from a picture
Good luck!
mrbb is online now
post #3 of 5 (permalink) Old 05-19-2015, 03:02 PM Thread Starter
mbod17's Avatar
Alright thanks. that was some great advice!
2002 honda recon es
mbod17 is offline
post #4 of 5 (permalink) Old 05-19-2015, 07:29 PM Thread Starter
mbod17's Avatar
wow, that was very usefull! it is being sold by a honda/suzuki dealer. It doesnt say how many hours and it has the title.
2002 honda recon es
mbod17 is offline
post #5 of 5 (permalink) Old 05-19-2015, 11:45 PM
sabre54's Avatar
Liked: 4 times
Everything that the boys above have said and also I see damage to the plastic where the owner has sewn it back together, the tires look good but check for cracks in the rubber, I see one plug in the right front tire that wasn't trimmed off. Check the exhaust for extensive rust, that is an expensive fix if the muffler is rusted out, check the rear brake pedal and see if it still operates properly, I see so many of them seized up and that will give you a clue on how it has been maintained. There is no digital display so you won't be able to tell how many hours or miles it has on it, it also doesn't have the full length footwells. Overall it looks like it has been well maintained in the pics but also well used. If everything checks out, see if the seller will take 1500 or 1600 for it. I used to have a 2006 350 and it never let me down, when I sold it, it had over 18,000 miles on it.
1996 Foreman 400 FW, 2007 420FM Rancher,2008 420FM Rancher,2009 Foreman 500 FPM
sabre54 is offline
