"89 300 trx no lights, won't turn over, keeps blowing fuse??? - Honda ATV Forum
post #1 of 8 (permalink) Old 02-08-2012, 03:52 PM Thread Starter
svanprooyen's Avatar
Unhappy "89 300 trx no lights, won't turn over, keeps blowing fuse???
Ok, very new here so don't bash me to badly, I have a "89 300 TRX and it recently had a dead battery, at least thats what my friend who rode it that dqay said, I charged the battery, it checked out to be good, but I have no control lights (neutral, etc) I also noticed that the 15a fuse in front of the battery was blown, I replaced it and it blew again, what do I need to do next? I'm somewhat mechanically inclined but I have no idea where to start and I really can't afford to have it taken to a shop...PLEASE any suggestions!
~Scottie
svanprooyen is offline
post #2 of 8 (permalink) Old 02-08-2012, 04:41 PM
Liked: 4281 times
welcome to the forums...first..find out why the fuse keeps blowing ?????..this is the very first thing you need to do !..then we can help you from there. more than likely..you got a shorted wire somewhere ??????...trace it from the battery through the wire harness.
post #3 of 8 (permalink) Old 02-08-2012, 05:48 PM
cmanningjr's Avatar
Liked: 423 times
What he said, you have a bare, burnt, broken or frayed wire some where.. Find it and fix it...
'91 TRX300FW
'86 TRX125 Project
cmanningjr is offline
post #4 of 8 (permalink) Old 02-08-2012, 06:29 PM
Liked: 27 times
Welcome to the forums. Does the fuse blow as soon as you replace it or does it blow after you turn the key on?
post #5 of 8 (permalink) Old 02-08-2012, 10:32 PM
jkhuntin's Avatar
Liked: 21 times
Welcome from the Volunteer state. You're in good hands above.
2013 Rancher 420 AT.
jkhuntin is offline
post #6 of 8 (permalink) Old 02-12-2012, 01:07 PM Thread Starter
OK today is the day I get to try to fix it!! The fuse seems to blow when I turn key on, I unplugged, cleaned, and re-plugged all connections, I inspected the wires and found nothing that looked broken, frayed, or out of the ordinary. I seem to be getting a solid connection through the wires, about to reconnect everything and hoping it was just a bad connection, let you know what happens.
post #7 of 8 (permalink) Old 02-15-2012, 01:11 PM
tdi
tdi's Avatar
You might try to disconect the headlamp switch and see if the fuse still pops.If it dont ,your short might be in the switch on the handle bar. The wires are routed realy tight up in there,and you might need to take it appart and make sure no wires are touching the bar where it clamps.
84 trx 200 "stock" 95 trx 300 fw all new tan plastic ,91 trx 300 built to resemble a early 88 with the grey plastic ,08 Rancher 420 fm white,05 Rincon ,Its rough with a bunch of miles "8k",soon to be white with 08 plastic .I LOVE Honda atv projects almost as much as I like riding them!!!!!!!
tdi is offline
post #8 of 8 (permalink) Old 02-15-2012, 08:41 PM Thread Starter
It work!!! Cleaned all connections an WOW. It works!! Thanks for the help...I will definatly be back. Thanks Again for all the advice. Wait, what is the recommended tire pressure on a '98 text 300???
