99 XR400r new piston, rings and valves - Honda ATV Forum
 2Likes
  • 1 Post By SlammedRanger
post #1 of 7 (permalink) Old 07-13-2019, 01:48 PM Thread Starter
XrMelTrx's Avatar
My XR is making me loose weight over here! 😆 I recently replaced the piston, rings, sleeve, valve stems and springs. Bike won't turn over from kicking, it acts like it wants to but doesn't. I pull started and it ran briefly while giving a little throttle. Since it ran do you think I still have a compression problem?
XrMelTrx is offline
post #2 of 7 (permalink) Old 07-13-2019, 04:53 PM
SlammedRanger's Avatar
Liked: 1324 times
Check the normal. Fuel,spark,air. Start with a shot of starting fluid in the intake tube. Will it pop off on that? If yes you have a fuel problem. Clogged carb. Bad fuel shut off. Gas cap vent clogged. Something along those lines. If it still dosnt pop off on starting fluid go to spark. You should smell gas when kicking it over in this case. Remove the plug and hold it to the side of the motor or frame or what have you and see if you have a good fat blue spark. If you have spark then do a compression test. Now it is possible the flywheel woodruff key is sheared. Not super likely but possible. This would make it spark at the wrong time and not start.
misterclean59 likes this.
07 416ex
To many mods to list in signature(ran out of space lol)
Check out garage for full list
SlammedRanger is offline
post #3 of 7 (permalink) Old 07-16-2019, 08:28 AM Thread Starter
XrMelTrx's Avatar
SlammedRanger I wanna thank you for this forum! With y'all help I was able to get a 99 xr400r thats been sitting for at least 4yrs diagnosed, doctored and now starting 1st kick! Thank you everyone that chimed in
XrMelTrx is offline
post #4 of 7 (permalink) Old 07-16-2019, 08:47 AM
misterclean59's Avatar
Liked: 637 times
What was the problem?
misterclean59 is offline
post #5 of 7 (permalink) Old 07-16-2019, 09:53 AM
Liked: 1324 times
Your welcome! Always happy to help! But i am curious also what fixed it.
_Wilson_ likes this.
07 416ex
post #6 of 7 (permalink) Old 07-16-2019, 09:59 AM Thread Starter
XrMelTrx's Avatar
After addressing the initial compression issue with a new piston turns out one of the valve stems was very slightly bent, enough to keep it open. Replaced those and it was a matter of figuring out the valve adjustments. The exhaust needed to be a little slacker and intake to spec.... No smoke from the tailpipe a lil smoke seems to be burning off by the exhaust but I think its from sitting so long
XrMelTrx is offline
post #7 of 7 (permalink) Old 07-16-2019, 10:05 AM Thread Starter
XrMelTrx's Avatar
One of you guys mentioned that sometimes you have to back off on the valves a little. I backed off all of them at 1st, it started acting like it wanted to turn over every kick just wouldn't quite do it. So I figured enough gas mix wasnt getting in so I tighten the intake to spec and BINGO!
XrMelTrx is offline
