fuel choice for your honda - Page 3 - Honda ATV Forum
post #21 of 33 (permalink) Old 03-02-2012, 09:07 AM
kawa11@ptd.net's Avatar
Liked: 4 times
yeah I run av. fuel Its 100 octane and clean!! no additives in it!! it runs great an my quad and its alot cheaper than race fuel!! and I have a small airport 2mi from my house so why not run it! lol at 6.00 a gal. its way cheaper than race fuel at 8.50 a gal.? it makes the throttle response instant! and has a unique smell to it?
2002 426ex 11:1 hi comp. wiseco,hot rods crank,stage 2 hotcam,rev max cdi box,ported intake & exhaust,header welds ground down,uni filter,lexx slip on,pro armor tether swtch, ,tusk nerfs,msr quick adj. lever, moose hand guards,moose bar hold down,renthal bars,xrf rear grab bar,moose bar hold down,rock front bumper,DG front frame guard,pep steering stab,alba alum gas cap,covers,HB racing rear brake block off,gripper seat cover,shock covers,custom 426 graphics,,,air scoops,tusk alum. shifter,
post #22 of 33 (permalink) Old 03-02-2012, 01:03 PM
Dan G's Avatar
Any jet changes on that? I'm wanting to run a little higher of an octane in my prairie I'm building with a little lead in it for top end lube... stuck between 100ll and some vp u4.4. The 4.4 is oxygenated so It'll give more power, but for 90 bucks per 5 gallon I won't need that unless I enter a xc race with it, and even then I'd be mixed 1:4 or 1:3 with 93.... I'm figuring I can run the 100LL 50:50 with 93 if your having good luck out of it...
Dan G is offline
post #23 of 33 (permalink) Old 03-04-2012, 09:36 AM
Mudslinger11's Avatar
When I bought my new Rancher back in December and I was getting my how to operate tour, the guy told me running 87 octane was fine and that is what I run in my sons 95 Timberwolf also.
2011 Honda Rancher 420 2x4
In The Mud
Mudslinger11 is offline
post #24 of 33 (permalink) Old 03-04-2012, 01:09 PM
jrock31's Avatar
i personally would never use mid grade. how many people does anyone kno that uses that crap anyways. it just sits in the tanks at the gas stations for very long periods of time. between unleaded and premium. i personally use premium but unless your quad says to use it your fine using unleaded
jrock31 is offline
post #25 of 33 (permalink) Old 03-04-2012, 02:47 PM
falconblack's Avatar
I always use 87 octane in all my stuff never had a problem but I do add seafoam if it sits more then a month just to stabalize it as our gas is not near what it used to be.
falconblack is offline
post #26 of 33 (permalink) Old 03-04-2012, 05:26 PM
Alfresco's Avatar
My manual says 92. One station where I live sells non-ethanol 89, so that's what I use. Maybe I'm wrong, but I'm thinking non-ethanol 89, is probably better than ethanol 92.
2000 400EX
Alfresco is offline
post #27 of 33 (permalink) Old 03-06-2012, 02:19 PM
bflee's Avatar
I have tried to tell some of my friends and coworkers about the octane rating system and differences in fuel as I learned in HVAC school. My5sons explained it well with that article. Some just refuse to believe it but lower octane fuels have more heating power than higher octane fuels. The octane rating only refers to the ignition point. Jet fuel has a lower octane than regular unleaded. If they ran the higher octane they would call it a missile instead of a jet because thats what it would end up looking like. Higher octane fuels ignition point is higher to keep it from detonating from compression and heat before the end of the piston stroke. The engineers know a little more about this than I do so just put in what the manufacturers recommend. You are not going to gain by going above it.
07 Rancher TE stock except for gun rack.
bflee is offline
post #28 of 33 (permalink) Old 08-13-2012, 11:18 PM
01SSRedA4's Avatar
Liked: 24 times
I run 93 in all my small engines. Weed eater, 4 wheelers, riding mower. I also add 1 to 2 ounces of Stabil to each 5 gallon can when I bring it home from the gas station.
06 Foreman 500 - 29.5 OG Laws, SS212s, 35%, Warn 2.5k, HL^2", <2.5">, EPI, HMF
95 Fourtrax 300 - 27" Zillas, SS212s , Viper 3k, HL^2"
04 XR80 - Stock
07CRF50 - Stock
01SSRedA4 is offline
post #29 of 33 (permalink) Old 08-14-2012, 06:38 AM
Habs_Fan's Avatar
I only use 93 in mine (also in all outdoor power equipment) but it's mainly because I always fill up my car when filling up the gas containers. Since the car requires 93 it's just easier to keep dispensing in the container rather than having to re-swipe the card to fill the container and for a 5 gallon container it only costs about $1 more. Plus, I figure it can't hurt anything by using 93.
Habs_Fan is offline
post #30 of 33 (permalink) Old 08-17-2012, 08:53 PM
MattR's Avatar
In my area of WI, non ethanol fuel is only available with premium grade and I run it mainly to avoid the ethanol problems.
1986 Honda TRX350 4x4
1987 Honda TRX350D FourTrax Foreman 4x4
WI ATV Riders facebook group
https://www.facebook.com/groups/624749707573938/
Just because I give you advice doesn't mean I know more than you,
It just means I've done more stupid stuff than you.
MattR is offline
