Ruined my engine! - Page 2 - Honda ATV Forum
 47Likes
post #11 of 26 (permalink) Old 06-30-2019, 07:46 AM
mac102004's Avatar
Liked: 2049 times
Looks like it. I know the Honda GX engines have it.
_Wilson_ likes this.
2015 Honda Rubicant FM7
- 28" Mud Bugs
- Powermadd Handguards
- ODI Grips
- 31x11" Outlaws
- NPP Dual Dominators
- ECM Reflash
- TheBOM Mag+ Cams
- TwinAir Air filter
- Delrin Motor Mounts
- Aluminum Valve Covers
- Gorilla Through Shaft
- TigerTail
mac102004 is online now
post #12 of 26 (permalink) Old 06-30-2019, 02:39 PM
_Wilson_'s Avatar
Liked: 1803 times
Originally Posted by TBRider View Post
I got my stepson to mow my lawn and within an hour he managed to blow up the rear end, after getting the busted rear end out, I found a dry case. Not a drop of grease or fluid, thankfully I can get a replacement rear end for 50 bucks.
Was that transaxle a hydrostatic unit (tuff torq) or old school gear drive transaxle ? Cause $50 is a good deal on a hydrostat unit! Heck I'd bite if i could find one (in good shape) for $50 .....
misterclean59 likes this.
_Wilson_ is offline
post #13 of 26 (permalink) Old 06-30-2019, 02:52 PM
TBRider's Avatar
Liked: 235 times
Its an old school one with gears
2017 Rubicon TRX500FM6
2500 lb KFI winch and KFI mount
VIP Flare windshield with mirrors
26" Maxxis Bighorns
72W 9" LED light bar
Heated handlebars and thumb warmer
K&N Oil filter
TBRider is offline
post #14 of 26 (permalink) Old 06-30-2019, 02:55 PM
TBRider's Avatar
Liked: 235 times
After reading this and posting earlier went and had a peek at the rubi, fluids were all good, but a chipmunk was storing about a pound of sunflower seeds in my rear box and my airfilter box, caught and escorted 6 of them out of my shed last week....
misterclean59 and _Wilson_ like this.
26" Maxxis Bighorns
K&N Oil filter
TBRider is offline
post #15 of 26 (permalink) Old 06-30-2019, 03:05 PM
_Wilson_'s Avatar
Liked: 1803 times
Moth balls and pepper mint spray..... Will help solve rodent issue :-) mice nest under the engine cooling shroud on my snapper 15 ohv.... A nother member mentioned maybe taking his shroud off during certain times of the season, IMO thats a good idea.... IF, you have on going rodent issues, for now I've been leaving the hood up (she's dryed stored)
Was there any damage to the air foam element ??
TBRider likes this.
_Wilson_ is offline
post #16 of 26 (permalink) Old 06-30-2019, 03:06 PM
Liked: 6777 times
I have had Chipmunks as pet , Alvin was his name , no doubt ... But are they any good eatin' ???? looks like a plump squirrel to me , fried squirrel is a good meal !!!!!
TBRider likes this.
fishfiles is online now
post #17 of 26 (permalink) Old 06-30-2019, 03:46 PM
TBRider's Avatar
Liked: 235 times
Luckily enough they didn't chew any wires, got in through the air intake.
26" Maxxis Bighorns
K&N Oil filter
TBRider is offline
post #18 of 26 (permalink) Old 06-30-2019, 04:21 PM
_Wilson_'s Avatar
Liked: 1803 times
I ran into that same issue too, only the pest was those degum @&$'?:!! mud dobbers, i took some galvanized storm door screen, n some zip ties, and fashioned it over the tube, cured that problem, lol, mud dobbers, cause major issues with machines around here, ive even run nto plugged gear box vent lines!! AND yes ..... This is another place honda dropped the ball!! Every (TUBE design ) intake should have been (pre cleaner type) factory screened!
TBRider likes this.
_Wilson_ is offline
post #19 of 26 (permalink) Old 06-30-2019, 06:12 PM
_Wilson_'s Avatar
Liked: 1803 times
check the oil in everything!
Very True, but Not easily done .... When you have many machines to look after.
Some of the machines i operate have many gear boxes to check 7 alone! on my. Fwd closed station kubota .....SO.... I can understand ... SOME gear boxes being over looked due, to time, oil type/grease, and drive unit use, but! The Power plant?? (crank case oil) those should be checked. Before, and after each use!
This auger angle gear drive, died from lack of grease, a simple couple pumps of mystic grease is all the drive needed!! in the end i FIRED the gofer, but the whole deal cost me $800+ i bullet proofed the new gear drive. Live and learn
Got lube ??
fishfiles likes this.
_Wilson_ is offline
post #20 of 26 (permalink) Old 07-01-2019, 06:19 AM
TBRider's Avatar
Liked: 235 times
My wood chipper gets a shot of grease every time it goes to work, always better to grease when warm so the grease will run within the bearing.
26" Maxxis Bighorns
K&N Oil filter
TBRider is offline
