96 300 Honda is about to get the best of me - Page 2 - Honda ATV Forum
 5Likes
post #11 of 28 (permalink) Old 04-18-2019, 08:16 PM
Liked: 1411 times
Originally Posted by Tymartinizgood View Post
Originally Posted by Goober View Post
Check out the service manual on setting the decomp cable. TDC just like valve setting 1-3 mm slack? Lube that cable mebbe stickin?
I rechecked the timing with a screwdriver in the spark plug hole and this is where Iím at w piston at its highest point. Is this my problem?
Jumped time and piston hitting valve. Check valve position at TDC.
Goober is offline
post #12 of 28 (permalink) Old 04-18-2019, 08:46 PM Thread Starter
Tymartinizgood's Avatar
I rechecked the timing with a screwdriver in the spark plug hole and this is where I’m at w piston at its highest point. Is this my problem?
Goober, I got a feeling your right my friend. I’ll tear the valve cover back off in the morning and let you know what I find out. It’s been put back on with red silicone gasket maker anyhow, is this what I should use when I put it back together?
Tymartinizgood is offline
post #13 of 28 (permalink) Old 04-18-2019, 10:00 PM
Liked: 4279 times
never...ever !!!..use rtv sealant !!!!, yamabond or hondabond for the rocker box.
post #14 of 28 (permalink) Old 04-18-2019, 10:02 PM
Liked: 4279 times
jumped time, timing is off. stretched cam chain ?, or sheered flywheel key ?.
post #15 of 28 (permalink) Old 04-18-2019, 10:21 PM Thread Starter
I can do a little engine work, top end mainly, not sure what a flywheel key is or even how to get to it. I guess I could attempt it though, if you guide me through it of course haha. I think that goober is onto something, he said in another thread that a cdi box won’t work on certain year models. Well I can tell you this much, the previous motor did run off the cdi box I have now but I’ve never heard this motor run before and the side cover and starter are all different? So this could also be another potential problem I’m worried about, I can easily put it back in time and replace chain if it’s stretched. I’m attatching a pic of the numbers in this motor I’m trying to get to run and could you all tell me if I need to get different cdi box?
post #16 of 28 (permalink) Old 04-18-2019, 10:29 PM
Liked: 4279 times
I can do a little engine work, top end mainly, not sure what a flywheel key is or even how to get to it. I guess I could attempt it though, if you guide me through it of course haha. I think that goober is onto something, he said in another thread that a cdi box wonít work on certain year models. Well I can tell you this much, the previous motor did run off the cdi box I have now but Iíve never heard this motor run before and the side cover and starter are all different? So this could also be another potential problem Iím worried about, I can easily put it back in time and replace chain if itís stretched. Iím attatching a pic of the numbers in this motor Iím trying to get to run and could you all tell me if I need to get different cdi box?
you already stated in one of your post, your getting spark, and fuel, so this tells me your good on that much. what your not good at..is timing and compression, if the timing is way off ?, you will never get it to fire the spark plug at the correct time !. engine numbers dont mean nothing to me, I go by vin numbers, and I dont even need this , as you already said your getting a blue spark ^^^^^^^^^^^, what your not getting is what I have laid out here, timing, and spark at the correct time !. and you need to run a compression test, throttle held wide open, crank it over with spark plug in boot, laying on engine, what do you see on compression reading ?, you need at least 100 psi min for it to run !.
post #17 of 28 (permalink) Old 04-18-2019, 10:32 PM
Liked: 4279 times
oh, and the flywheel key is on the flywheel side ( left side ), its sitting down in the end of the crank in a slot, wedged between the crank and flywheel, this keeps the flywheel in time to everything, if this key sheers ?, then this will throw the timing off big time !.
post #18 of 28 (permalink) Old 04-18-2019, 10:35 PM
Liked: 1411 times
This pic of TRX300 engine numbers is out of the manualĖthe TE06E-82xxxxx engine you show appears to cross ref to a 1987 TRX250.
ID:	135760   Click image for larger version
ID:	135762   Click image for larger version
Goober is offline
post #19 of 28 (permalink) Old 04-18-2019, 10:37 PM
Liked: 4279 times
This pic of TRX300 engine numbers is out of the manual–the TE06E-82xxxxx engine you show appears to cross ref to a 1987 TRX250.
lol, he put a trx250 motor in a trx300 frame ?..lol.
Goober likes this.
post #20 of 28 (permalink) Old 04-18-2019, 10:46 PM
Liked: 1411 times
So very important that you check the VIN regarding your saying itís a 96 TRX300; you said the 1988 engine ran in it?
Okay so anyway see the parts link in my sig block? Click the rocky mtn link and select atv, then year, then youíll see a list of quads with VINs. Search for your VIN and wallah you can determine your model year frame.
Engine Listing
https://www.hondashop.com.au/wp-cont...l-ID-Chart.pdf
1988 project check this man out!
https://www.hondaatvforums.net/forum...-trx300fw.html
Goober is offline
2000 TRX450FM Build/Mods fishfiles Builds, Projects & DIY 1083 06-14-2019 12:13 PM
Ongoing project, 300 fourtrax. SamUK Builds, Projects & DIY 619 06-28-2018 01:44 PM
clutch kit and gear reduction question mudking16 Honda Rancher 19 12-13-2017 07:57 PM
