oil leak on 400ex - Honda ATV Forum
Old 02-19-2011, 07:39 PM   #1 (permalink)
miami305honda's Avatar
Member #8647
View miami305honda's Photo Gallery(0)
oil leak on 400ex
on my 08 400ex i got a shirt caught up in the front sprocket and it started leaking from the seal behind the sprocket. Do i need to pull engine apart to fix or can it be done externally??? So frustrated with this where do i start? the service manual doesnt help.
2008 400ex stock
2008 450er gutted exhaust, jetting, -1 front tooth, modquad afs, k&n air filter, mesh screen airbox cover.....
miami305honda is offline   Reply With Quote
Old 02-19-2011, 07:48 PM   #2 (permalink)
Fourtrax's Avatar
Member #2063
View Fourtrax's Photo Gallery(0)
Welcome to the forums! I don't know the answer to your question but I have a counter question.. How in the world did your shirt get caught up in there? HAHAHA?
Someone that DOES know the answer will be round shortly to help you out.
1988 FourTrax 300
Fourtrax is offline   Reply With Quote
Old 02-19-2011, 08:05 PM   #3 (permalink)
wilhelm77's Avatar
Member #8636
View wilhelm77's Photo Gallery(0)
Make sure your oil isn't too high I had a problem with leaking when it was too high
wilhelm77 is offline   Reply With Quote
Old 02-19-2011, 08:12 PM   #4 (permalink)
my5sons's Avatar
Member #7182
Do a search next time!
How to chance the Oil seal behind front sprocket on 2003 400EX
I think when he says 'pic' he means a seal 'pick' or hook and pick set (img below) or you can use a drywall screw and then pull the old seal. Get the new seal lined up and tap it in with a socket of approximately same size.
2001 Suzuki LT A50
2003 TRX300EX
2006 TRX250EX - Maxxis Razrs
Old 02-19-2011, 09:39 PM   #5 (permalink)
Fourtrax's Avatar
Member #2063
Dang, He's new, its cool. I' still more interested in HOW he got his shirt stuck in there. HAHA!
1988 FourTrax 300
Old 02-19-2011, 09:48 PM   #6 (permalink)
Welcome to the forums. Yes, like stated above, the seal can be changed without taking the engine apart. Just take the sprocket off. Drill a couple holes in the seal on each side and use sheetrock screws or a similar screw. Just drill a small hole, just big enough to get the screws started and turn them in a few turns, enough to hold good. Grip them with ViseGrips and pull the seal out. If needed, you can drill more than two holes. The pick set, like pictured above, can also be used to help get the seal out.
Put a little grease on the lip of the new seal and slide it over the shaft and make sure to start it straight. You will have to use a deep well socket or something long enough to go over the shaft to tap the seal in with. Set the socket on the seal and gently tap with a hammer and make sure you keep it straight or it can bend or leak. The outside of the socket should be about the same size as the outside of the seal. If you don't have a socket that will work, a thick piece of pipe will work, but make sure the end of the pipe isn't sharp or it might cut the seal.
Old 02-23-2011, 06:10 PM   #7 (permalink)
Member #8647
haha well long story short it was really a balaclava. I am coast guardsmen stationed in Valdez, ak and i went riding early winter and while putting it back in storage i had the balaclava on my lap and it slid down into chain with out me feeling it thru my thick snow pants lol and i didnt realize it till i rode it in and went back and forth a couple times. so it broke the plastic chain protector and fabric went all in the seal and still has shreds in it. rode it a couple times hopin it didnt really do much damage but leaks oil wen warmed up. I am in process of ordering the seals.
2008 400ex stock
2000 400ex oil leak
2000 honda 400ex common oil leaks
400ex leaking oil
400ex leaks oil when warmed up
400ex oil leak
four wheeler leaking oil around chain
front sprocket seal 400ex
honda 400 ex oil leak
how to make oil lines stop leaking on 400ex
inside 400ex motor oil seal by the front sprocket
my 400ex four wheeler is leaking oil in front of my cain
will it hurt your four wheeler if its leaking oil from motor gasket
