I am going to say your WRONG on a few things here, first if the dealer TELLS you NOT to follow the owners manuals SET times for PM"s , HONDA will tell you , your screwed, HAVE the dealer PAY for things if things go wrong, a dealer cannot superseded HONDA"S Spec's for when HONDA requires things done
and GOOD luck getting a dealer to SAY he TOLD you NOT to follow what's in your owners manual?
that's asking for a a HE SAID< SHE SAID conversation , you will end up loosing out on!
NEXT, as for Aftermarket parts NOT voiding a warranty
ANY time you ALTER the design by the maker, you can VOID your warranty, as you did NOT allow it to be used as OEM designed it
NOW will many dealers NOT fix something if you have larger tires on it or a pipe,
NO, MOST will turn a BLIND eye to it
BUT if they wanted to be sticks in the mud YES they most certainly CAN
the burden of PROOF< is tossed around a LOT on the web
some say the OEM must PROVE that the "X" part cause "X" problem
and legally as far as MY understanding goes, NO
it would NOT
all they would have to prove, is it was NOT in OEM condition
you would have to PROVE it DIDN"T cause"X" failure
and that will fall on you to PROVE, can very easy cost you more to do so that worth doing, and OEM"S know this
TAKING pictures?? sound's great, but vide would be better, as anything today can about be MADE
a HONDA dealer( and NO I do NOT use mine for about ANYTHING)
has certified techs, and blah blah blah, BUT when work gets done there, they get the BLAME IF something goes wrong , 10 times more than IF you do it and something fails
this will really come down to YOUR dealer and HOW Much a jerk or OK shop they are
they can BACK you or NOT, when THEY DIDN"T do ":X" work and problems develop
the thing I think MOST atv owners do is this
they BOUGHT a TOY, they use/abuse it, add what they WANT when they WANT< FIX when and as they wish
and IF problems happen, MOST suck it up as" SH!T IT HAPPENS"
so few fight the warranty deal any ways
but YES aftermarket parts can and WILL void warrantys, read the small print on a warranty some time? LOL
Sorry, just is what it is!
