2006 TRX350 4x4 no drive up front...? - Honda ATV Forum
Like Tree2Likes
Old 01-11-2017, 10:26 AM   #1 (permalink)
Paologray's Avatar
Member #84282
View Paologray's Photo Gallery(0)
Hi Chaps,
Here's another one for you:
I noticed my TRX350 FM6 doesn't have any drive to the front wheels. The propshaft/driveshaft turns when driving all the time, but it doesn't drive anything up front.
Would it be the splines in the cup joint just in front of the front diff that have worn/sheared, or could something else more sinister be afoot?
Thanks in advance
Paul
Paologray is offline   Reply With Quote
Old 01-11-2017, 12:44 PM   #2 (permalink)
Carolynskiii's Avatar
Member #84298
View Carolynskiii's Photo Gallery(0)
Did you put the bike in the air and run it to see if the front wheels turn?
If they don't turn then yes inspect all splines and work your way fourward till you find the problem. If all splines are good then the problem is with the front diff.
Carolynskiii is offline   Reply With Quote
Old 01-11-2017, 12:55 PM   #3 (permalink)
Member #33621
View Jeepwm69's Photo Gallery(0)
Liked: 406 times
If you have power to the rear wheels that same shaft turns the front driveshaft (it goes all the way through the motor), so yeah, you've got stripped splines on the front driveshaft somewhere, or your front diff has disintegrated. I think you'd know if it was the diff (grinding) so I'm guessing stripped splines.
Welcome to the forum.
Jeepwm69 is offline   Reply With Quote
Old 01-11-2017, 01:58 PM   #4 (permalink)
Paologray's Avatar
Member #84282
I've only had the front in the air (and been watching closely while my friend drives/spins the tyres in mud). Definitely NO drive at the front wheels.
I had the front end up today, and when I turn a front wheel the thicker part of the driveshaft that comes from the rear of the front diff spins independently of the driveshaft (the same one...) that comes from the engine.
What can we deduce from this please?
Old 01-11-2017, 02:00 PM   #5 (permalink)
Paologray's Avatar
Member #84282
Thanks Jeep. Please see my post above - would you say the diff internals are OK and it's the splines have been fudged?
Would I be able to weld the thicker collar (rear of the front diff) to the main driveshaft?
Old 01-11-2017, 02:38 PM   #6 (permalink)
Member #33621
Liked: 406 times
Yes, and yes, although replacing the driveshaft would be better. I've seen quite a few welded up like you're talking about.
Old 01-11-2017, 03:29 PM   #7 (permalink)
Paologray's Avatar
Member #84282
One assumes the problem with welding the driveshaft together is that you can't then pull it all apart if something goes wrong down the line?
Thanks for your help, by the way - it's most appreciated.
Jeepwm69 likes this.
Old 01-11-2017, 05:35 PM   #8 (permalink)
Liked: 1541 times
your problem is with your front differential. odd are, its right there where your drive shaft enters the pinion gear on the front differential.
Old 01-12-2017, 06:45 AM   #9 (permalink)
Paologray's Avatar
Member #84282
A little more...
I jacked up the front today, I can turn the bell that comes out the rear of the front diff by hand and both wheels turn in the same direction, back or forwards. It spins and the driveshaft stays still.
Can I assume my diff is OK?
Old 01-12-2017, 07:06 AM   #10 (permalink)
b52bombardier1's Avatar
Member #31787
View b52bombardier1's Photo Gallery(0)
Liked: 259 times
Your differential is probably Ok but I'd still worry about stripped splines on the driveshaft.
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
2006 Green Honda Foreman 500 - Viper Elite Winch
2004 Yellow Honda 250ex - Grandson's Bike
1971 School Bus Yellow "Spaghetti" Harley-D Sprint 350
1972 Candy Yellow Honda CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green Honda ST90 K0
1974 Mars Orange Honda CT90 K5
1975 Topaz Orange Honda ST90 K2
1976 Shiny Orange Honda CT90
b52bombardier1 is offline   Reply With Quote
