2006 Honda TRX 350 Rancher-Fuel Problem? - Honda ATV Forum
post #1 of 12 (permalink) Old 01-14-2011, 07:43 PM Thread Starter
erivers's Avatar
2006 Honda TRX 350 Rancher. Cannot get to turn over without the help of Starter Fluid. When I spray it into filter it fires up. But once it burns off it cuts right back off. Will not run at all without it. But it has no problem trying to turn over, so would not think it is spark plug or anything. Any ideas?
erivers is offline
post #2 of 12 (permalink) Old 01-14-2011, 07:45 PM
Carb needs cleaned.
post #3 of 12 (permalink) Old 01-14-2011, 07:57 PM
jkhuntin's Avatar
Liked: 16 times
And do not use starter fluid!!!!! Washes oil from the cylander wall, very abrasive on engine. Pour a capful of fuel in sparkplug hole or lightly soak rag in gas. See Helmut I can learn!!!!!
jkhuntin is offline
post #4 of 12 (permalink) Old 01-14-2011, 07:58 PM
jkhuntin's Avatar
Liked: 16 times
Oh and I agree with Helmut carb needs cleaning.
jkhuntin is offline
post #5 of 12 (permalink) Old 01-14-2011, 08:03 PM Thread Starter
erivers's Avatar
Ok, I will try that. And, I was just spraying it on air filter. Still not a good idea?
erivers is offline
post #6 of 12 (permalink) Old 01-14-2011, 08:06 PM
LOL. An even better way is to put gasoline in a spray bottle and spray it in the cylinder or in the back of the carb. That's usually the way I do it.
post #7 of 12 (permalink) Old 01-14-2011, 08:21 PM
A service manual won't really show you much about cleaning a carb, so I thought I would post this:
First, you need to take the carb off. Next, remove the bowl and remove the float and float valve. Now, remove all the jets and clean them and make sure the hole in the jets isn't clogged up. Hold them up to light and make sure you can see through them. If they're clogged up, use a piece of wire from a wire brush, the wire from the inside of a trash bag tie, a small sewing needle, or just anything small enough than you can poke through the jet and remove the clog. Don't use anything big enough to damage or wallow out the holes in the jets. Soaking them in carb clean will help if you have a hard time unclogging them.
Now, turn the pilot screw all the way in while counting the number of turns it takes to turn it in. Remember that number because you will need it to be able to put the pilot screw back to where it was. Just turn it in until it stops. Don't tighten it or you will damage the end of the screw. Now, remove the screw completely. There will be a spring, washer, and tiny o-ring on the screw, so don't lose them. The washer and/or the o-ring will probably stay down in the hole and you will need to dig them out with a tiny screwdriver or pick. While the pilot screw and all the jets are out, blow air through all the passageways in the carb body, especially the ones that the slow jet and pilot screw go in. Don't forget to blow air through the fuel inlet to the carb bowl and out the hole where the float needle goes.
Next, clean the inside of the carb and the carb bowl with carb cleaner and remove any buildup in the bottom of the carb bowl. Get the cleaned pilot screw and put the spring, washer, and tiny o-ring on in that order. The washer goes next to the o-ring, not next to the screw head. Be careful that the o-ring goes into the hole straight and square and put the pilot screw in and tighten it all the way in to the lightly seated position. Remember, don't over tighten or you will damage the end of the screw. Now, back the screw out the same number of turns that you counted when you turned it in earlier. Check the end of the float needle for damage and also check the hole where the needle seats for any damage or dirt buildup. Reinstall all the jets and reinstall the float and float needle and put the bowl back on. Reinstall the carb.
If the carb was real dirty and the passageways were stopped up in the carb body and you couldn't get them unclogged by blowing air through them, then you will need to soak the carb in carb cleaner overnight. You can buy one gallon buckets of carb cleaner from the auto parts store with a basket to hold the carb. Make sure you remove any rubber parts, such as o-rings before spraying carb cleaner or soaking the carb in carb cleaner. The carb cleaner will melt the rubber parts.
Here is a good link to read to familiarize yourself with cleaning carbs. It pertains to motorcycles, but ATV carbs are basically the same. They might look slightly different, but the cleaning procedures are the same.
How to Clean a Motorcycle Carburetor, the RIGHT way. Evan Fell Motorcycle Works
post #8 of 12 (permalink) Old 03-05-2012, 06:52 PM
johnieblaze's Avatar
helmut - where can I get that break carb breakdown w/ more detail. got one apart and have a brass washer that fell out... Not sure where it goes.
johnieblaze is offline
post #9 of 12 (permalink) Old 03-05-2012, 07:39 PM
Liked: 1713 times
carb needs cleaning...no fuel reaching carb..float sticking or stuck ?. and there is nothing wrong with spraying starting fluid into a air filter or carb !!!!!!!!..i've said this a million times..i guess this makes a million and 1 !..lol. it will not hurt the motor...IFFFFFFFFF YOU ONLY SPRAY IT IN SMALL AMOUNTS !!!..this is how i've been doing it for ..crapp..as long as i've been rebuilding motors in atv's !..15 yrs !..yessssss..if you spray alot all at once ??..then it will harm the rings !!..butttttt..if you just use it in short burst...too act as a starting point to narrow down your fuel problem ??..then no harm will come to your motor !!. i'll stake my rep on it !.
shadetree is online now
post #10 of 12 (permalink) Old 03-05-2012, 07:41 PM
Liked: 1713 times
only washer i know of ?..goes on the main jet needle..under the small c-clip !..that's the only washer i can think of ????. but it's not brass..it's just a plain washer that goes there !.
