How do I set the timing 86 TRX350 - Honda ATV Forum
Old 12-30-2010, 06:23 AM   #1 (permalink)
Ruger 3006's Avatar
Member #7579
View Ruger 3006's Photo Gallery(0)
Doing a top end rebuild and need to know how to set the timing. First bike rebuild , no books just going blind on this with the help of this forum. Thank You
Ruger 3006 is offline   Reply With Quote
Old 12-30-2010, 01:41 PM   #2 (permalink)
Old 12-30-2010, 08:00 PM   #3 (permalink)
Ruger 3006's Avatar
Member #7579
Thanks so much. The time instructions worked perfectly. But I have another problem . After assembly , we started the bike and have a strong ticking in the top end. Could give me some guidence on setting the rocker arm clearances. I'm not sure I did it correctly. I put the timing mark back for TDC the same as we did for timing. We set the rocker arm clearance at .004 at this point. Where did I mess up and what do I need to do to correct it???
Old 12-30-2010, 08:16 PM   #4 (permalink)
When you aligned the "T" mark up, were you on the compression stroke with the cam lobes facing down? If not, you need to turn the flywheel one full revolution and stop on the "T" mark again and you will be on the compression stroke and the cam lobes will be facing down. You need the cam lobes facing down in order to properly adjust the valve clearance. If the cam lobes aren't facing down, the valves won't be closed all the way.
BTW, the valve clearance should be set at 0.003in.
Old 12-31-2010, 07:06 AM   #5 (permalink)
Ruger 3006's Avatar
Member #7579
Thanks again. I found your post and illustrations 14 pages back that you posted to "theslug". We should finish this afternoon when my son-in-law shows up and we complete the bike. Couldn't have done it with out you. Thanks again
Old 12-31-2010, 08:32 PM   #6 (permalink)
Ruger 3006's Avatar
Member #7579
Thanks so very much again. The bike runs like a top. Couldn't have done it with out your help. You made this a cake walk. Keep up the GREAT work, it looks like many others out there need your help as much as I did.
350 trx honda timming setting
86 honda trx 350 timing
honda trx 350 timing marks
honda trx350 timing
how to check timing on trx350
how to set the timing in a 86 honda 350
how to set timing on honda trx 350
is it hard to set timing on a 350 honda atv
timeing on a trx 350
timing a trx 350
timing adjustment on honda trx350tm
