98 Fourtrax 300 4x4, no Spark. electrical issues - Honda ATV Forum
post #1 of 5 (permalink) Old 09-16-2009, 10:33 AM Thread Starter
bronco2guy's Avatar
I'm trying to help my father inlaw fix his 98 Honda 300 4x4 Atv and to give you the full details it started out with his battery not getting charge and having to use kickstarter, then eventually it wont start at all now. Checked spark and no spark. He took to shop they said regulator went bad and wasnt allowing battery to charge, it has new regualtor now still no spark, and all fuses good, killswitch fine, checked plug and coil both fine *worked on 96 Honda 300 Fourtrax*, my thoughts are 1 of 3 things, CDI, Pulse Genreator, or Stator? How do I check these, I ahte to pull side cover off if it ends up being CDI, there is power going to CDI but no signal out to coil when you crank it over. please help, thank you for looking.
bronco2guy is offline
post #2 of 5 (permalink) Old 09-16-2009, 11:14 AM Thread Starter
bronco2guy's Avatar
Correction rectifier -not regulator
post #3 of 5 (permalink) Old 09-16-2009, 11:17 AM
jrowe06's Avatar
Lightbulb
could it be a loose or bad connection?
jrowe06 is offline
post #4 of 5 (permalink) Old 09-16-2009, 03:35 PM
Saber6's Avatar
Liked: 5 times
Try swapping the cdi first with a known working one.
http://www.oilburners.net/forums/cus...atar1326_2.gif
BOOB man - "Brotherhood of Oil Burners" Local 715
Sometimes I wonder,.."Why is that Frisbee getting bigger,..? then it hits me,...
Saber6 is offline
post #5 of 5 (permalink) Old 09-17-2009, 06:02 AM Thread Starter
bronco2guy's Avatar
Yes, that is the plan is to try and fine a known working cdi to try next, the 96 her uncles has different CDI setup, so was unable to use it.
Lot easier than pulling side cover.
