400Ex Carburetor vacuum hose line question - Honda ATV Forum
Old 12-22-2010, 08:45 AM   #1 (permalink)
DcMetroCycle's Avatar
Member #7552
View DcMetroCycle's Photo Gallery(0)
I have no idea where the vacuum hose numbered 45 plugs into?
Someone could save the day by letting me know where she goes
Thanks Tony
DcMetroCycle is offline   Reply With Quote
Old 12-22-2010, 11:52 AM   #2 (permalink)
Member #417
Liked: 304 times
Welcomee to the forums.... I'm pretty sure that's a vent hose.
Old 12-22-2010, 01:00 PM   #3 (permalink)
Member #7552
So it just hangs lose?? I have a nail in the hose now to block it and the bike runs but fouls the plugs and runs crappy..
It fouled plugs and ended up going into storage for two years.. I pulled it out and cleaned the carbs still fouls the plug but runs even worse then before.
You can only ride for two hours before you have to clean the plug. You can run it longer then that but when you go to restart she just wont have it.
After taking the nail out of the number 47 vent tube any ideas?
Old 12-22-2010, 01:57 PM   #4 (permalink)
Member #417
Liked: 304 times
It sounds like the air bypass valve behind the black cover may be bad? Also check the choke lever and make sure it is tight and not on the first notch, check the air filter clean it or replace it.
Old 12-22-2010, 02:29 PM   #5 (permalink)
Welcome to the forums. I agree with Moose, #45 is a vent line.
Old 12-22-2010, 02:32 PM   #6 (permalink)
Member #417
Liked: 304 times
You would be best buying a rebuild kit from MOOSE utility, they aren't but about 20 bucks and well worth it. you probably still have gummed fuel somewhere in the carb.
Old 12-22-2010, 04:01 PM   #7 (permalink)
Member #7552
Can i get some more details on the air bypass valve behind the black cover?
I think your right about going with a rebuild kit I will order one tonight and let you guys know how it works out..
Thanks so much for the help
Old 12-22-2010, 04:33 PM   #8 (permalink)
Member #417
Liked: 304 times
If you haven't done a thorough cleaning on the carb I strongly suggest it.
Old 12-22-2010, 04:50 PM   #9 (permalink)
The air cutoff valve richens the mixture slightly when you let off the throttle quickly on deceleration to prevent a lean condition which causes a backfire.
I would go ahead and clean the carb and see what that does.
Old 12-22-2010, 06:37 PM   #10 (permalink)
tomgodd's Avatar
Member #126
View tomgodd's Photo Gallery(0)
Welcome to the Family! 45 is a vent tube. It plugs into a spot on the heat quard plate under the gas tank.
NEVER TAKE A SLEEPING PILL AND A LAXATIVE IN THE SAME NIGHT!
http://www.youtube.com/watch?v=Exbsw5ssn4I
Equal opportunity offender.
tomgodd is offline   Reply With Quote
2003 honda ex400 vacuumline goes to ?
2004 trx 400 carburetor vacuum hose installation
400ex carb hose routing
400ex carb hoses
400ex carburetor hose diagram
400ex vacuum lines
carburetor hose connections on a 2007 honda 450r
honda 400 ex carb tubing
honda 400ex carburetor hose diagram
polaris trailblazer 250 carb diagram
were vacum line run on 03 400 ex
where do the vacuum lines go to 2001 400ex
