honda recon oil change? - Honda ATV Forum
post #1 of 4 (permalink) Old 12-06-2010, 01:07 PM Thread Starter
wmkennedy25's Avatar
do i need to do anything other than change the oil and put new spark plug in? how much oil do i need to put back? havent had it but three weeks so i want to change before i ride too much due to me not knowing how long its been since its been changed! any help is greatly appriciated!
wmkennedy25 is offline
post #2 of 4 (permalink) Old 12-06-2010, 01:51 PM
Liked: 24 times
You might want to check and clean the air filter and check the oil level in the differential.
1.7 quarts. Make sure you use an oil designed for wet clutches. Most automotive oils have friction modifiers that will make the clutch slip. The recommended oil is Honda GN4.
post #3 of 4 (permalink) Old 12-06-2010, 02:21 PM Thread Starter
thanks for the reply! im not real sure about the oil in the differential never messed with that before but of course im new so any tips on that? what kind of oil would it need? sorry im asking so many questions im just new but i am a quick learner! thanks again!
post #4 of 4 (permalink) Old 12-06-2010, 02:31 PM
Liked: 24 times
The oil fill hole for the diff is on the main top of the diff. On the left side of the diff, down near the bottom, there's a check bolt. Remove the check bolt and pour gear oil through the oil fill hole until oil starts to run back out the check bolt. Reinstall the check bolt and reinstall the top oil fill plug. When you remove the check bolt if oil is already coming out, you won't need to add any gear oil. Remember to check the oil level with the ATV sitting as level as possible.
For the diff, use SAE 80 Hypoid gear oil.
For the engine, the recommended oil is Honda GN4, 10W-40. In colder temps, use 5W-30.
