Transmission rebuild???? - Honda ATV Forum
post #1 of 44 (permalink) Old 11-02-2010, 05:59 PM Thread Starter
Deer hunter's Avatar
Well I posted on here a while back about my clutches slipping in my 2000 rancher 350. Well the problem seems to be getting much worse. Im fairly mechanicaly inclined and im planning on replacing the clutches. My questions are is this hard to do and what is required. I looked on cheapcycleparts.com under transmission and it didnt list them as clutches so what else could these be called. Also how many clutches are there? Thanks for the help
Deer hunter is offline
post #2 of 44 (permalink) Old 11-02-2010, 06:12 PM
On cheapcycleparts.com, look under "engine and exhaust" and then it's listed under "clutch" and they're called friction discs and clutch plates.
post #3 of 44 (permalink) Old 11-02-2010, 06:24 PM Thread Starter
Ok thanks. The clutches are located in the transmission arnt they.
post #4 of 44 (permalink) Old 11-02-2010, 06:32 PM
They're not actually on the inside where the gears are, but they're under the front crankcase cover.
post #5 of 44 (permalink) Old 11-02-2010, 07:12 PM Thread Starter
So do you have to pull the motor for this?
post #6 of 44 (permalink) Old 11-02-2010, 07:27 PM
You can do it with the engine in the frame, but it's a lot easier to just remove the engine, or I think it is.
post #7 of 44 (permalink) Old 11-02-2010, 07:37 PM Thread Starter
Yea I probably will just remove it bacause I need to fix an oil leak and I'd say it would be easiest to remove it because it looks easy to remove. Is there any good repair manuals for hondas?
post #8 of 44 (permalink) Old 11-02-2010, 07:49 PM
You can download a factory service manual for the 350 Rancher for free at the link below.
http://www3.telus.net/leneng/pdf/Hon...air_Manual.pdf
post #9 of 44 (permalink) Old 11-03-2010, 07:37 PM Thread Starter
I have amsoil 10w 30 in right now. The owners manual says thats ok. could this be the problem or are the clutches just warn out?
post #10 of 44 (permalink) Old 11-03-2010, 07:45 PM
If the oil you're using is safe for wet clutches, then I would say the clutches are worn out.
