Old 09-30-2010, 01:16 PM   #1 (permalink)
mxz-rider's Avatar
Member #5549
View mxz-rider's Photo Gallery(0)
2001 recon making noise in the axle
I have an 01 recon and I think the bearings are bad in the axle. looking at the rear end, it is the left side of the axle that makes a grinding noise, opposite the break, when you spin the wheel. Im not sure what it is but was told that it might be the bearings? - any suggestions on what to do
mxz-rider is offline   Reply With Quote
Old 09-30-2010, 01:52 PM   #2 (permalink)
Welcome to the forums. Yeah, it sounds like the bearings are out.
Old 09-30-2010, 03:09 PM   #3 (permalink)
mxz-rider's Avatar
Member #5549
Do I need to pull the axle to replace the bearings and do you know of a website that I can get a parts diagram? easy fix?
Old 09-30-2010, 05:55 PM   #4 (permalink)
Potato_Gun's Avatar
Member #1831
View Potato_Gun's Photo Gallery(0)
Babbitts Sports Center | Arctic Cat OEM Parts | Can-Am (Bombardier) OEM Parts | Honda OEM Parts | Polaris OEM Parts | Sea-Doo OEM Parts | Ski-Doo OEM Parts | Suzuki OEM Parts | Yamaha OEM Parts
And yes bearings are usually a fairly easy repair
Potato_Gun is offline   Reply With Quote
Old 09-30-2010, 06:24 PM   #5 (permalink)
as long as it's the bearings..and not the ring gear or pinion gear !..lol.
Old 10-01-2010, 04:58 AM   #6 (permalink)
mxz-rider's Avatar
Member #5549
can you guys give me some basic directions to get started - Does the axle slide out once I take the locking nuts off and is there a specific way it should come out.
Old 10-01-2010, 02:23 PM   #7 (permalink)
Remove the left hub and right hub, axle nuts, brakes and the axle knocks out the right side.
01 honda recon rear bearing
01 recon installing rear axle
02 honda recon rear axle diagram
2001 honda recon 250 rear end
2001 honda recon left rear axel bearing repair
2001 honda recon rear end
2003 250 honda recon rear axle diagram
how to disassemble rear axle on 07 honda recon
instruction on how to change back bearing trx honda 250 recon 2000
rear end for a 2001 honda 250 es recon quard
schematic for rearend on 01 honda recon
