2007 420 Rancher solenoid problem - Honda ATV Forum
Old 09-25-2010, 02:44 PM   #1 (permalink)
hanginmoss58's Avatar
Member #5367
View hanginmoss58's Photo Gallery(0)
I have a 2007 420 rancher es that keeps toasting the starter solenoid. I have replaced the battery and the solenoid. The solenoid went out again. Replaced the solenoid and it went out again. Now I have no power at all. All fuses are good in fuse box and battery tested at 12.56 volts. ANY SUGGESTIONS.
hanginmoss58 is offline   Reply With Quote
Old 09-25-2010, 02:51 PM   #2 (permalink)
Liked: 1385 times
if you keep blowing fuses..then you have a short somewhere...if you don't have any power what so ever..then your main fuse is blown..i have never seen selonoids shorting out..other than from time..if something keeps toasting it..you got a bad short from battery to selonoid..this would be my guess...your starter isn't locked up is it ?..check to make sure your starter still works...check all your leads from battery to starter..and from battery to ground.
Old 10-03-2010, 07:27 PM   #3 (permalink)
Member #5367
Are you talking about the fuse labeled main fuse in the fuse box (30 amp) or something else.
Old 10-03-2010, 09:40 PM   #4 (permalink)
Liked: 1385 times
yup..thats your main fuse..make sure it's good..check your battery leads to your battery..selonoid..and then to the starter..somewhere in that line leads..is a short..or somewhere in your wireing..( a hot wire..more than likely )..has rubbed through the wireing harness..and is touching bare metal..and when you turn the key on..your grounding out..causing the fuses and such to blow.
Old 10-07-2010, 12:23 PM   #5 (permalink)
Member #5367
Found the problem. In the positive battery cable there is a relay in the quick connect plugin. It is between the battery and the fuse box. There is also a cable that runs to the solenoid in this cable. The dealer calls it battery relay cable. Thanks for all the help. From your suggestions of checking all the wires lead me to this relay. It cuts the power from the battery to the fuse box and the soleniod.
Old 10-08-2010, 12:24 AM   #6 (permalink)
Liked: 1385 times
sweet..glad you fixed it.
07 honda rancher 420 starter solenoid
2007 honda 420 starter
2007 honda rancher 420 starter relay
2007 honda rancher 420 starter solenoid
2007 honda rancher battery good no power
2007 honda rancher starter
2007 honda trx 420 keeps burning main fuse
honda rancher starter solenoid
how to know if a starter solenoid is bad on a honda rancher 420
is solenoid working on honda 2007 trx420
solenoid problem for honda 420 atv
starter on 2010 honda rancher
