1987 trx 350 4x4 still stalling - Honda ATV Forum
Old 08-28-2010, 08:48 AM   #1 (permalink)
ironsetr's Avatar
Member #3401
View ironsetr's Photo Gallery(0)
I have posted the same problem on here before but can't figure it out. Pulled and cleaned the carb put in a rebuild kit new jets and stuff. The problem that I'm still having is she starts and idles fine every time. When I go to put it in gear it stalls. It is intermittent, this will happen for a few minutes than it will go. When this is happening i can reach down with my hand and pull up on the shift lever and just before it goes into gear it will stall. Also when i do finally get it going I'll be going down the road then all of a sudden it will cut out, if i downshift into neutral before it stops rolling it idles fine and i can keep going again. Is there any type of switch in that is connected with the shifter in the trans? it has been intermittent for a couple of years now. I'll have weekends when it doesn't do it at al,l and then sometimes it happens all the time. Sorry so long a post just really frustrated. thanks in advance
ironsetr is offline   Reply With Quote
Old 08-28-2010, 08:52 AM   #2 (permalink)
Member #417
Liked: 300 times
You have a neutral switch and a reverse switch either one will give you an issue if they are bad but they are not usually intermitten, they usually fail all together. If you set your Idle too low when you pop it in gear it will cause the engine to stall too.
Old 08-28-2010, 08:56 AM   #3 (permalink)
Liked: 1499 times
turn your idle up..and did you check your fuel pump ?..it has a elec fuel pump on it..it also has a fuel pump control box..right rear behind a black cover. this tells the fuel pump to shut off after it reaches so much pressure
Old 08-28-2010, 09:36 AM   #4 (permalink)
ironsetr's Avatar
Member #3401
the fuel pump is pulsating about once every second don't know about the control box or what to check there. tried the idle doesn't change things. if i warm it up sometimes it will go get 100 yards and stall,stall,stall, then all of a sudden it will go and run for hours. if i turn it off sometimes it will go and sometimes it will go thru the stalling again
Old 08-28-2010, 09:47 AM   #5 (permalink)
Liked: 1499 times
check your float needle..from what your saying..it's running out of fuel..start at your gas tank..and go from there to your carb..i think your float is sticking..and your running out of fuel...if it runs fine when you first start it..then yeah..it's running out of fuel..about a 100 yards..and yeah..you used up your carb bowl gas..and it's not re-filling back up...check your float needle..make sure it's not sticking...also check your float itself..make sure it's set right.
Old 08-28-2010, 09:56 AM   #6 (permalink)
ironsetr's Avatar
Member #3401
i just replaced all the jets and the float needle pin. this has been going on for a couple of years. sometimes i can run it for four days without a problem then it will do it again constantly then it may go away. it seems to happen in bunches sometimes it will do it very often and sometimes not at all
Old 08-28-2010, 11:27 AM   #7 (permalink)
Liked: 1499 times
did you change the fuel filter lately ??..clean the tank out ??..it's not getting enough gas..your float is not letting enough gas into the carb..check all of this.
Old 08-28-2010, 11:39 AM   #8 (permalink)
ironsetr's Avatar
Member #3401
changed fuelfilter awhile ago about 2months ago maybe the fuel pump just needs to be replaced it is the original would i have to get a oem?
Old 08-28-2010, 11:49 AM   #9 (permalink)
Liked: 1499 times
good luck on that !!..lol..number 1..even if you can find one..thats gonna cost about 200 or more..second..no..you do not need a oem fuel pump..do what i did..go to advanced auto parts..tell them you need a low pressure 12v fuel pump..they are around 40 bucks..their round..i think they are about 4 psi..somewhere around that ??..they fit perfect into the same holder..only thing you will have to do..is redo your fuel lines..they will be different angles and so forth..but..for the price..you can't beat it !..oh..and you will need to cut off the leads from your old fuel pump..and splice them into your new fuel pump..use butt conectors..they work great.
Old 08-31-2010, 08:22 AM   #10 (permalink)
ironsetr's Avatar
Member #3401
Thanks for all the help Shadetree i just can't understand why this is a intermitten thing, you really seem to think it is a fuel issue though? like i said before when i reach down and pull up the shift lever by hand just before it goes into gear it will stall. i can let the shift lever down and it will idle fine> What I'm saying is that i don't put it in gear but just before.
1987 honda 350 fourtrax stalling when shifting
1987 honda trx350 problems
38710-ha7-671
87hondatrx350startsstalls
honda 1986 fourtrax 350 4x4 stalls when put in gear
honda 38710-ha7-671
honda fourtrax trx 350 engine dies in gear
how to fix problem with a quad when is stall when shifting gears
how to repair honda 350 trx stalling problem
neutral switch 1986 honda 350 fourtrax
trx250 stalls
used part atv control unit 38710-ha7-671
