1986 TRX300 4x4 Timing - Honda ATV Forum
Old 07-20-2010, 07:14 PM   #1 (permalink)
billw129's Avatar
Member #4168
View billw129's Photo Gallery(0)
Hello all
I am new here and I have a question about my TRX300. I started to notice some noise coming from my motor the other day and it started to blow smoke. I tore it down and the cylinder was a little marked up. I ordered a new piston and ring's kit, had the machine work done and now I am stuck. I can rebuild a 2 stroke but don't know much about the 4 stroke's. How do i set the timing on this thing? also The piston that I got was .050 over do I have to re-jet the carb? If so what jet should I use? Also on a 2 stroke I know that you have to re adjust the needle and run at wot and check plug and re adjust as necessary but how do I do it on a 4 stroke? Thank you all very much in advance.
billw129 is offline   Reply With Quote
Old 07-20-2010, 07:27 PM   #2 (permalink)
Welcome to the forums. Are you sure it's an '86? I don't think they started making the Fourtrax 300 until 1988. If it's an '86, it might be a Fourtrax 350. Let me know for sure if it's the 300 or 350 and I'll post instructions for timing it.
You shouldn't have to worry about rejetting it.
Old 07-20-2010, 09:37 PM   #3 (permalink)
billw129's Avatar
Member #4168
It is a 1989. I was wrong lol sorry about that. I was told it was an 86 but I just checked the plate and it is an 89. I am glad I will not have to re jet that will save me some money.
Old 07-20-2010, 09:48 PM   #4 (permalink)
Here you go. Just make sure you put the cam in with the lobes facing down. You don't have to make that tool to retract the timing chain tensioner. You can use a small flat screwdriver to retract it. You just have to hold it in the retracted position until you get the tensioner bolted back on.
Old 07-20-2010, 10:15 PM   #5 (permalink)
billw129's Avatar
Member #4168
Helmut you are a god. I have been reading a lot of the posts here and you seem to know everything about these machines. Thank you. This will make my day tomorrow much more easy. Ok so now after i get the timing set how do I go about setting the needle with the clip on it? Thank You
Bill
Old 07-20-2010, 10:27 PM   #6 (permalink)
Bill
I don't think you will need to rejet or adjust the needle, either one, because of the 0.50 overbore. It should be fine.
Old 03-07-2011, 06:57 PM   #7 (permalink)
pat2330b's Avatar
Member #8264
View pat2330b's Photo Gallery(0)
Hi, i'm new to this forum too i got a trx 350 1986 do you have this timing file for this or a link. I got an noise coming from the engine when its cold. Ithink there a loose in the timing chain i got to check this out. a lot of smoke too in warm up.
ThX love this forum !!
Pat
pat2330b is offline   Reply With Quote
Old 03-07-2011, 07:15 PM   #8 (permalink)
Pat
Welcome to the forums. Here are the procedures for the '86 Fourtrax 350.
Old 03-07-2011, 07:33 PM   #9 (permalink)
Liked: 1528 times
Bill
hes not god..he's just one heck of a pic man around here !!..lmfao..he's not the only one that knows these machines !..lol.
Old 03-07-2011, 07:37 PM   #10 (permalink)
my5sons's Avatar
Member #7182
Between his pics and your paintings, you guys could be an awesome team!
2001 Suzuki LT A50
2003 TRX300EX
2006 TRX250EX - Maxxis Razrs
1986 honda 300 four wheeler
86 honda fourtrax 350 put in time
honda 300 timing
honda 350 fourtrax 4x4 timing marks
honda atv 300 set timing
honda fourtrax 300 ignition timing
honda fourtrax 300 timing
honda fourtrax 300 timing marks
how to set the timing on a honda 300 fourtrax
how to set the timing on fourtrax 300
how to set timing on 300 fourtrax
how to set timing on honda fourtrax 300
