2006 350 Rancher Starting Problem - Honda ATV Forum
Old 06-23-2010, 07:34 PM   #1 (permalink)
highplaces's Avatar
Member #3639
View highplaces's Photo Gallery(0)
Question 2006 350 Rancher Starting Problem
Solenoid clicks but most times starter will not spin. Just replaced solenoid , but to no avail. Also checked/ charged battery: showing 12,8 v with my voltmeter
highplaces is offline   Reply With Quote
Old 06-23-2010, 07:44 PM   #2 (permalink)
Welcome to the forums. If your battery is good and you've already replaced the solenoid, then your starter is probably bad. Make sure all the cables on the battery, solenoid, and starter are clean and tight.
The next time the starter doesn't turn, tap it with a hammer and see if it turns. If it does, the starter is bad.
Old 06-23-2010, 08:21 PM   #3 (permalink)
ET 300's Avatar
Member #3591
View ET 300's Photo Gallery(0)
Connect your volt meter to the starter electrical terminal and a good ground. Try starting. You should read battery voltage when you press the start button. If you DO have battery voltage, your starter is the problem. One last check you can do is a direct feed to the starter terminal. Hook a jumper cable to the battery positive and touch the starter terminal. If the starter does not turn you have a starter problem.
I just had a starter problem. I replaced the starter brushes and I am back in business.
ET 300 is offline   Reply With Quote
Old 06-23-2010, 08:57 PM   #4 (permalink)
highplaces's Avatar
Member #3639
Thanks! That was it!
2006 honda rancher 350 starting problems
2006 honda rancher starter
2006 honda rancher starter problems
2006 honda rancher starter removal
honda rancher 350 starter problems
how to remove starter on honda rancher 350 2006
how to replace a starter on honda rancher
how to replace starter on honda 350 rancher
instructions on how to replace starter on 2006 honda rancher
starter removal from 06honda rancher
starter solenoid for 2006 honda rancher
