Old 05-01-2010, 04:56 PM   #1 (permalink)
Gaba's Avatar
Member #3012
View Gaba's Photo Gallery(0)
Question 2006 450 trx transmission oil change
Hello there, I am wondering if anyone of you guys know how to change or drain the transmission oil out of my 2006 450 trx?
Thanks!
Gaba is offline   Reply With Quote
Old 05-01-2010, 05:05 PM   #2 (permalink)
Redracer's Avatar
Member #618
View Redracer's Photo Gallery(0)
Welcome to the site, is this a 450R? The sport quad?
Dynamic Graphics, Inc.
Aurora Honda
LoneStar Racing
Leatt
Fox Shox
HondaATVForums.NET
Redracer is offline   Reply With Quote
Old 05-01-2010, 05:09 PM   #3 (permalink)
If it's a 450R, then this is how.
Old 05-01-2010, 05:16 PM   #4 (permalink)
Redracer's Avatar
Member #618
That is for an 04-05 model. Everything is the same minus the drain bolt is on the other side. That one shows the drain under the foot brake, the 06+ models the drain for the tranny is under the shifter/front sprocket. Look down towards the bottom frame rail. All the bolts look the same except the one that you actually remove to drain the oil.
Aurora Honda
LoneStar Racing
Leatt
Fox Shox
HondaATVForums.NET
Old 05-01-2010, 05:19 PM   #5 (permalink)
Yeah, your correct Red, that is for the '04-'05 model. That's the only manual I have for the 450R.
Old 05-01-2010, 05:23 PM   #6 (permalink)
Redracer's Avatar
Member #618
There are a few differences but the 04-05 manual will work for most things. The main differences are obviously the tranny drain, the early models has an external oil cooler, and the early models have the same carb style as the 400EX and 06+ has the same carb as the CRF450.
Aurora Honda
LoneStar Racing
Leatt
Fox Shox
HondaATVForums.NET
06 honda 450r oil change
2006 honda 450r oil change
2006 honda trx450r oil change
2006 trx 450r oil change
2006 trx450r oil capacity
2006 trx450r transmission oil change
honda 450r transmission oil change
honda trx 450 oil change
honda trx450r transmission oil change
how to change transmission oil in a honda 450r
trx450 transmission oil
