Trx250x oil leak - Honda ATV Forum
Old 06-20-2013, 08:15 PM   #1 (permalink)
Northertrx's Avatar
Member #30938
View Northertrx's Photo Gallery(0)
Trx250x oil leak
Alright guys I have yet another question about my 1987 trx250x. So I was warming it up and went for a ride around my back yard and I had been getting on the throttle a bit but not over revving it. I come back into my garage and park it and I noticed that it was dripping oil from behind the drive sprocket on the motor. Does anyone know what this is? This is still new to me for the most part but I be leave this is not normal.
Northertrx is offline   Reply With Quote
Old 06-20-2013, 08:57 PM   #2 (permalink)
Member #417
Liked: 286 times
There is a "C" clip behind the sprocket that holds a small oil seal in place. Maker surer the clip is there if not get one. If it is get a new seal you cam pull it out with a pick.
Old 06-21-2013, 06:24 AM   #3 (permalink)
Northertrx's Avatar
Member #30938
Thank you trx2five0
Old 06-21-2013, 08:40 AM   #4 (permalink)
Northertrx's Avatar
Member #30938
Do u know the mane of that seal by chance
Old 06-21-2013, 11:08 AM   #5 (permalink)
SUPERJJMJ's Avatar
Member #28318
View SUPERJJMJ's Photo Gallery(0)
Liked: 4 times
Just go to the store and tell I'm where its located and they will tell you what's the name or use the repai manual
SUPERJJMJ is offline   Reply With Quote
Old 06-21-2013, 07:56 PM   #6 (permalink)
Member #417
Liked: 286 times
It's the shift shaft seal
Old 06-21-2013, 08:18 PM   #7 (permalink)
SUPERJJMJ's Avatar
Member #28318
Liked: 4 times
Wouldn't the shift shaft seal be on the shift shaft
It wold be the output shaft gear
Old 06-23-2013, 07:31 PM   #8 (permalink)
Northertrx's Avatar
Member #30938
Lol I got one ordered from honda for 6.00$ but I have one more question does someone know the specs for lug nuts
Old 06-23-2013, 08:59 PM   #9 (permalink)
Member #417
Liked: 286 times
Yes you are correct! Duh. . I meant input shaft. Lol
Old 06-24-2013, 01:17 AM   #10 (permalink)
SUPERJJMJ's Avatar
Member #28318
Liked: 4 times
1/4 turn past hand thread
1987 honda 250x gear shifter seal
87 250 x leaking oil by front sprocket
front sprocket for 1987 honda 250x
honda 250x forums
how change oil in 1987 250x
how to change front sprocket oil seal on 1987 250x
how to fix oil seal on honda 250x 1987
oil leaks on top of motor on a 87 trx250
replacing 250x honda output shaft on engine
trx250x leaking oil through output shaft
trx250x sprocket seal
where is 1987 trx250x shifter shaft located
