Old 04-07-2010, 03:52 PM   #11 (permalink)
According to my repair manual, the Fourtrax 300 only rated for 5 amps at 5,000 RPMs.
Old 04-07-2010, 04:01 PM   #12 (permalink)
submarine 300's Avatar
Member #1660
Very true but what he will be charging will only be in mAh so it should be ok.
300 Fourtrax 4x4 2" lift, 14" ss106 wheels, custom Dual chrome snorkels, gear reduction, supertrap ids2, disc brakes, moose seat pack,
Old 04-07-2010, 04:07 PM   #13 (permalink)
He wouldn't be able to use the full capacity of the 150 watt power inverter, though, because it would draw about 12 amps, like Pain said. He would need to figure up the wattage of whatever he wants to use and then convert to amps to figure out if it will work or not.
He might be able to use it anyway, and just put a charger on his battery at night to charge it back up. That would work as long as he didn't use so many amps that it would run the battery down while he was still using the power inverter. Also, it might shorten his battery life a little bit.
Old 04-07-2010, 04:14 PM   #14 (permalink)
Member #1660
Yep it could very well shorten his batt. life if it takes awhile to charge the stuff he wants but if it charges at a reasonable rate and he rides or runs the engine for a while after charging it might be ok. I guess it's one of those things he will just have to try and see how well it works.
Old 04-07-2010, 04:20 PM   #15 (permalink)
Yeah, if I really wanted to use that power inverter, I would go ahead and try it anyway. Like you said, if he isn't going to be running too many amps on it, it'll probably be OK anyway.
The charging system on those 300s didn't put out too many amps, but most of the newer ATVs charge more. I guess more and more people are riding everyday and they are using more and more accessories, so they had to start building them with bigger charging systems.
Old 04-07-2010, 04:23 PM   #16 (permalink)
Member #1660
lol maybe I need to get a new quad I would like a wide screen tv on mine!
Old 04-07-2010, 05:20 PM   #17 (permalink)
Pain's Avatar
Member #690
View Pain's Photo Gallery(0)
Yeah, I wouldn't use it with all 150w, at least not for very long. For a couple phone chargers it won't be an issue. For a laptop a typical power supply is about 90w, give or take, but even that is a little ambiguous and would probably draw much less to charge.
Pain is offline   Reply With Quote
Old 04-08-2010, 10:39 AM   #18 (permalink)
Dooley's Avatar
Member #2389
View Dooley's Photo Gallery(0)
Taken all on board!! Thanks chaps, will let you know what and what doenst work.
Cheers.
Dooley is offline   Reply With Quote
atv have power inverter
atv inverter
atv power inverter
inverter for atv
inverters for atv
power inverter atv
power inverter for atv
power inverter for atv four wheeler
power inverter on atv
power inverters for atv
use inverter with atv
using a quad with inverter
