TRX 350 - how to remove gas tank - Honda ATV Forum
Old 03-13-2013, 02:13 PM   #1 (permalink)
michael_rides's Avatar
Member #29389
View michael_rides's Photo Gallery(0)
Hi all. I have a year 2000 Honda Rancher 4x4 350. It is in great shape but hasn't been run in a few years - it's been sitting inside my garage. Just put a new battery in but it won't start. The cranking part goes just fine now that I have a new battery, the engine just won't fire.
The tank has about 1/3 tank and the gas is bad - no products were added when I stored the bike. Wanted to drain the tank so I removed the fuel line from the carb and nothing came out, even though the fuel valve was turned to "on".
I tried to blow into the fuel line while the valve was turned to on but I couldn't get air to blow into the line. It appears to be clogged upstream somewhere.
What would you recommend for next steps? I know I need to get that fuel out and likely do something to unclog whatever is preventing fuel from traveling down that line. Any advice would be VERY appreciated.
michael_rides is offline   Reply With Quote
Old 03-13-2013, 02:14 PM   #2 (permalink)
Member #7607
View Manny's Photo Gallery(0)
Liked: 185 times
instead of removing the tank, just remove the petcock, two phillips head screws usually hold them on. take that out, blow out the tank real good, disassemble and clean the petcock, then reinstall with an inline fuel filter and you should be back up and running.
HONDA parts for sale
Old 03-13-2013, 02:22 PM   #3 (permalink)
Member #29389
Sorry for my ignorance. Is the petcock the valve that you can turn to off, on, or reserve? Does the fuel line go from the tank, to the petcock, and then on to the carb?
Old 03-13-2013, 03:46 PM   #4 (permalink)
Member #7607
Liked: 185 times
The petcock is what sits on the left hand side bottom of your gas tank. its what controls on/off/reserve. the petcock comes from the gas tank, and the gas line runs from the carb to the petcock.
Turn the petcock to the off position....remove the gas line then from the petcock nipple, THEN remove the petcock, it'll probably be messy because the gas will want to pour out the bottom of the tank once you remove the petcock. however, you can jack up the left side of the entire atv and the gas will rush to the right side of the tank to allow no gas to exit out the hole once the petcock is removed.
02 honda 350 rancher es gas tank removal
2004 honda rancher gas tank removal
honda 350 rancher gas tank removal
how to pull the gas tank out of a 2006 honda 350 rancher
how to remove fuel tank from honda 350 rancher
how to remove gas tank off honda 3 wheeler
how to remove honda rancher es gas tank
how tomremove gas tank from trx350 honda rancher
how tor remove honda fourtrax petcock
pulling gas tank on 350 rancher
removing the fuel tank honda recon
replace fuel tank honda rancher
